Results 11 to 20 of 26
Thread: cutting vga cable
  1. #11
    Dec 2006
    Austin, TX
    How are you going to extend the shield of the cable? At the very least, you will want to make sure to reconnect the drain wire, if there is one.
  2. #12
    Variable Bitrate mayhembdm666's Avatar
    Mar 2008
    Adelaide, Australia
    I would suggest you find a decent length premad vga cable like an extension one and then cut the one end of and solder that to the internal board of your screen.. This way all your doing is replacing the cable with a longer one and not cutting and having a ugly join that will pickup and give of noise.
    2004 Holden WL Caprice Auto GENIII
    Base System = Raspberry Pi
    Everything else is pending for now as switched from a Mini-ITX setup
  3. #13
    Nov 2002
    Atlanta, GA, USA
    I didn't splice into the VGA cable, but I did de-solder the right angle connector off my Liliput 629, stuffed 3 single row headers in it's place, then ran a half dozen jumper leads from that header to one on a close by motherboard header (~6 inches). I got a fair bit of RF interference but eliminated nearly all of it by upping the refresh rate from 60 to 72 Hz and clamping a ferrite bead around the bundle.
    Save virtual trees....
  4. #14
    Jan 2005
    as to extending the shielding that is rather simple I plan to use shielded cable as the add in and connect the 2 shields
    about modifying the screen it self I would prefer not to actually modify the LCD and thanks for the ferrite tip
  5. #15
    Variable Bitrate dMand's Avatar
    Oct 2007
    The Evergreen State, Washington
    I don't recommend cutting and splicing the VGA cable. The signals have a tight tolerance and are very unforgiving. Besides, you could very easily screw up the motherboard/video card. Good luck!
    As others have suggested, a simple y cable or extension would be your best bet. Also, make sure you cover the spare output on the Y cable.
  6. #16
    Low Bitrate yam125's Avatar
    Oct 2008
    Tracy, Ca
    ok, i can bet that you are not going to like the results at all. so you are going to have to buy a new cable along with the extension you should have purchased in the first place.
    hint: spent 7 bucks and get an extension
  7. #17
    Jan 2005
    i have an extension however as i stated if i use an extension it will not work due to where the coupling will be or i windup with 5.5ft of cable coiled up beside the pc un less someone knows where to get an extension for the 10-pin round liliput cable
  8. #18
    Oct 2008
    Tracy, Ca
    extend it from the pc
  9. #19
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Wow, seems like your putting yourself through a mission. I would never dare extend my VGA cables and risk breaking my screen and or MoBo. 3 out of 5 screens in my setup needed to be extended. I simply bought VGA extensions and called it a day. On one I had a ton of extra cabling, but that was solved by simply rolling it up and tucking it away. All you have to do is connect the extension together then roll it up at the middle and tuck it under the carpet.
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
  10. #20
    Feb 2006
    Dallas
    Maybe you can find one here, goggle is your friend.
    "short vga extension cable"
    http://www.showmecables.com/showProd...egory_id=17184
  1. Replies: 5
    Last Post: 07-21-2008, 05:19 AM
  2. less quality with extention vga cable
    By maniac76 in forum LCD/Display
    Last Post: 03-27-2006, 01:27 PM
  3. Wanted: Ultimate VGA extension cable.
    By Jzor in forum LCD/Display
    Last Post: 02-24-2006, 03:38 PM
  4. VGA Cable causing engine noise
    By sq_geek in forum Car Audio
    Last Post: 12-28-2004, 12:47 PM
  5. Low profile Vga Cable?? Lilliput Vga too big!
    By biglips31 in forum General Hardware Discussion
    Last Post: 11-11-2004, 11:28 PM
