Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: cutting vga cable
    Jan 2005
    cutting vga cable
    has anyone cut and extended the vga breakout cable for there liliput? I am asking because I need about 6 extra inches on my VGA cable and was hoping someone has done this just want to findout about any signal loss or interference you may have had.
    Thanks,
    Yonu
    Jan 2005
    thought of that but I don't want to have to get a 6ft cable to make up literally 6in so I was hoping someone had done it before and could tell me how it worked out
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Well I need also about 6-8inches, but then to be able to panel mount the socket.
    Trying to solder a 15VGA connector is a no no unless you are damn hot (pun intended) at soldering.
    Jan 2005
    I was planning to simply extend it in the middle not at the vga
    Jan 2008
    Dartmouth, MA
    This guy may do what you want:
    It's a vga Y-adapter, but who says you're forced to use the second cable?
    http://www.newegg.com/Product/Produc...82E16812816037
    My Nearly Complete Car:
    http://www.mp3car.com/vbulletin/show...ed-car-pc.html
    Micro Control Center... Control Your Car Across the Internet
    http://www.mp3car.com/fusion-brain/1...-internet.html
    Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
    http://paulfurtado.com/
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by yonu View Post
    Even so, beaking in the middle of the cable is probably going to introduce interference unless you do a very good job.
    Quote Originally Posted by PaulF View Post
    I already have one for the rear screens and have considered using this for the primary one but would prefer just a single.
    Jan 2005
    guess I will just cut it goto soldering and hope for the best
    Jan 2005
    ok that is what I wanted to know guess I will have to get out the good soldering iron instead of the portable one
    Thanks,
    yonu
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Thanks,
    yonu
    LOL I once extended an ide ribbon cable 6 feet using CAT-5 - failed miserably but - now i know!
  1. Replies: 5
    Last Post: 07-21-2008, 04:19 AM
  2. less quality with extention vga cable
    By maniac76 in forum LCD/Display
    Last Post: 03-27-2006, 12:27 PM
  3. Wanted: Ultimate VGA extension cable.
    By Jzor in forum LCD/Display
    Last Post: 02-24-2006, 02:38 PM
  4. VGA Cable causing engine noise
    By sq_geek in forum Car Audio
    Last Post: 12-28-2004, 11:47 AM
  5. Low profile Vga Cable?? Lilliput Vga too big!
    By biglips31 in forum General Hardware Discussion
    Last Post: 11-11-2004, 10:28 PM
