Can you say "Distraction?" I too am interested in this project.
Project λ^2 (Lambda Squared or Lambda II)
[☺☺☺☺☺☺☺☺] Install 80%
Saving $ for PSU
Coming soon: freeflashstuff.net
It will be my business site, and it will also have a section dedicated to my previous and current builds.
HiJackZX1 w/ The Tobiathin Core PC system!
ZOTAC GF9300-G-E
INTEL E8200
4 Gigs
OCZ Vertex 2 SSD
OPUS 320
1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
Starting Raspberry Pi multizone project.
I wonder if it could be wrapped in one of those sticky page protectors or maybe a vacuum-sealed bag? I wonder if it would impede the touchscreen use?
Just a thought...![]()
OK, so thats good to know.
Still thinking about the monitor though....
Right now, I'm thinking of using a small laptop, like one of those 7" deals. split up the clamshell, extend the monitor cable and mount the screen in a waterproof enclosure where the instruments panel is. Then keep the computer itself in a custom enclosure in the seat.
The only thing I am concerned about is if the computer will have enough power to do what I need it to do.
Buying a weatherproof monitor can be pretty expensive. Furthermore, mounting one on a bike or motorcycle means that the device must be able to withstand moisture, extreme temperature, and vibration.
With that said, you could go a cheaper route and seal the entire unit yourself using silicone.
Silicone sealants are used to protect and seal anything from the smallest silicon chip to the worlds tallest skyscrapers. Sealants are available in a wide range of product forms including free flowing, cure in place gasketing, elastomeric silicone rubber and lubricating greases. When applied properly, silicone is extremely stable under the aforementioned conditions.
I would advise to spray all PCB's with a silicone grease after sealing ribbon and molex connections using an elastomeric automotive grade silicone. Research those from Dow Corning which are available for use in temperatures ranging from -40° to 450° F (-40° to 232° C). Dow Corning has innovative products to meet your exact needs, and has helped customers with solutions that go beyond what you would get from any other supplier. They've assisted me with instructions on how to weatherproof my door mounted CCFL LCD.
Here is their silicone website:
http://www.dowcorning.com/default.aspx?bhcp=1
Check out my CARPC: Project Diamond Plate
Quick Reference:
CPU Electrical Specs
Power Supply Calculator
Video Connections for newbies
Temperature Converter
Voltage Calculator
Avengerki
PC Install: 85%
Car PC: Revo-Sys X300 Double Din: 1.3GHz Pentium
Software install and setup: 35%
Entertainment Package: 85%
dMand, do you have any issues with the internal temperature of the monitor getting too hot?
How long does it take you to make a waterproof monitor?
Have a product you would like to sell on the mp3Car Store? PM me for more information.
Have a car computer question? Ask me by emailing the store.
