Results 1 to 6 of 6
Thread: Lilliput problems
    Nov 2008
    Lilliput problems
    Hi I need some help regarding my 7" Lillput touch screen. The problem is I carn't 'touch' the bottom left hand corner of the screen. I have calabrated the screen loads of times, but I still have the problem. I have Draw tested the screen and when i draw a straight line from the top left to the bottom left I get this.
    Can anyone help?
    James
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    That's odd. Is it still under warranty? Sounds like the touch panel needs replaced. Also did you go thru the advanced point calibration? It has something like 16 points... I can't recall off the top of my head.
    Tidder
    Try RevFE
    Nov 2008
    I have only done the four point calibration. The monitor is second had, the thing is if I touch there, the mouse still works just not under your finger.
    James
    Sep 2003
    New Mexico, USA
    Try doing the extra calibration just to see... that's odd... could be panel or controller, hard to say. Also, has it been taken apart? You may want to try the touch with the front bezel off, it could be pushing or tweaking something.
    Tidder
    Try RevFE
    Nov 2008
    Thanks to all I did the advance calabration and it sorted it!
    James
    Sep 2007
    West Springfield, MA
    Yeah, that's something that people should make note of. Do the higher point calibration, it works so much better. If that's not in the FAQ, it should be.
  1. Lilliput 7" EBY701 Problems - Not working?
    By hatchback19 in forum LCD/Display
    Last Post: 04-24-2008, 04:11 PM
  2. Replies: 1
    Last Post: 04-13-2008, 05:05 PM
  3. MacMini problems with Lilliput
    By simmo in forum MacCar
    Last Post: 11-07-2007, 11:06 PM
  4. EPIA M10000 + Lilliput 619 problems
    By Calipso in forum General Hardware Discussion
    Last Post: 04-04-2007, 09:42 PM
  5. Lilliput and ribbon cable problems
    By Udonboy in forum LCD/Display
    Last Post: 11-08-2004, 08:24 PM
