Originally Posted by
Slate
hmm.. ripped it completely off? Can you get a picture of it?
If I am imagining this correctly, the connector was pulled off, along with the pads of the PCB, and maybe even parts of the traces. Maybe one of these traces got torn. If this is the case, it could be an easy fix for someone who knows how to use a soldering iron. Can you see if there are any damaged traces, especially on the left side of the connector?
Do you have a DMM, or know someone who does? The easiest way to figure out what is wrong, is by doing a continuity check. Test each pin and make sure it is connected correctly on both ends of the cable, and make sure that one pin is not shorting to another (this could happen if the ribbon is not aligned right).
