The Xenarc 700TSV CCFL does all that so I assume the LED version they have would work better.
Hi,
Im looking for new 8" LCD because my 1 year old CTF-800 is TOO HOT and have big problems when outside is little colder wearther(-5°C)
What Im looking:
-Size: 8" touchscreen
-If is possible then I would like have widescreen(16:9)
-LED backlight (Because is colder than normal)
-It can be TMR or transreflective but is not so important
-Operating temperature from -10°C(can be lower too -20°C) to 50°C or more
-Can be open frame or in normal case
So can someone help me with right choise?
Thanks.
Regards, _Dejan_
Ampie Case
256 MB DDR2 PC5400
Xenarc 700TSV - VGA Monitor
Intel D945GCLF Motherboard
M2-ATX-HV
2005 Honda Civic
There is meant to be a LED 8" Lilliput on the market too now maybe an option.
Please read again my post.
-This LCD is 7" I looking for 8"
-Operating Temperature: 23°F ~ 158°F = -5°C ~ 70°C I need that work in lower temperatures.
-do not use LED backlight
Do you know which model?
For now Im find next one but I don't know If is all data real...
LinITX 8"
Ampie Case
256 MB DDR2 PC5400
M2-ATX-HV
2005 Honda Civic
"should work in the same temperatures" doesn't mean nothing. Why? If LCD will not turn on when outside temp will be -10 or -20°C what can I do? I can't return LCD because they are write that work from -5°C to 70°C...
I have CTF-800 and it doesn't work below 0°C(light just flashing) and I can't do nothing because in manual write that work from 0°C to 50°C...
So Im loking for LCD where manufacturer "provide" me that will work at -10°C or beter -20°C...
BTW 705TSV is 7"![]()
The 8" Lilliput model is 889GL-80NP/C/T, you will see them on ebay stating they now have a LCD backlight instead of CCF (it's widescreen format like the CTF-800).
Im find this model and look very nice and is very cheap.
Bout I can't find anywheere in which range normaly work...
Im contact lilliput for this data and I waiting for response...
Thanks.
Regards, _Dejan_
Im receive answer from lilliput:
Our item 889gl-80npct (8" 16:9 lcd vga touchscreen pc monitor,if you need the 8" 4:3,you can choose 859gl-80npct) the operating temperature will be -15 °C t0 60°C,( but the -20°C -70 °C is Critical point).
So I think 889gl-80npct is right choise for me![]()
Good luck. However after reading these forums for 3 years, I've seen many more complaints about the Lilliputs not turning on in even mild temperatures where my Xenarc and many like mine work in temperatures 40-50 below. I just hope it works out for you, maybe the newer technology fixed this.
Ampie Case
256 MB DDR2 PC5400
M2-ATX-HV
2005 Honda Civic
