Results 1 to 10 of 14
Thread: Facts about getting a 800*480 resolution to work!
    May 2006
    Hi
    I have read and read on the forums, and searched both the forums and on google, and i still didnt found any clear info.
    So can you please post your information on how you got your setup to work?
    Like this maybe:
    Videocard, Fabricant and model
    Screen, Fabricant and model
    Other info, like what program you used to get the resolution, and what settings.
    For my setup i would be like this:
    NForce 7050, Zotac 610i-ITX
    Linitx LIN70ATPC-SAU
    Best Regards
    Morten
    FLAC WuNgUn's Avatar
    Sep 2007
    I just run mine (8") at 1024X768...
    It doesn't give me that widescreen option in XP.
    Jun 2009
    having same issue, someone help??
    Feb 2009
    I could never get it to work - Did a lot of looking around to, but basically its not able to work with my Dell Inspirion 1520 laptop.
    Oh well, 800x600 looks just fine on my 7" Xenarc ITD
    Raw Wave tbird2340's Avatar
    Oct 2003
    Poland, OH
    I have a Zotac IONITX board with an Nvidia graphics chipset.. It has the ability to create custom resolutions but I don't know what to set for the timing and refresh rate etc... Anyone know?
    Current Vehicle: 2007 Dodge Nitro
    Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
    First Vehicle: 2003 Ford Ranger
    Constant Bitrate sergatiuk's Avatar
    Mar 2006
    guys, there is a nifty little program called "power strip", its free and does magic with video cards, get it and try to play around with it.
    also you can find modded graphic drivers at http://downloads.guru3d.com/
    they work better then the drivers that are provided by manufacturers, they also offer more options in most cases.
    if the modded drivers and/or powerstrip cannot output the desired resolution then your hardware is simply not capable of outputing this res.
    good luck
    2007 Toyota Tundra Double Cab SR5
    >"Say what you mean and mean what you say"<
    FLAC SFiorito's Avatar
    May 2004
    I'm running 800x480 on my Zotac ION board simply using NVIDIA's control panel. All I had to do was set the custom resolution, using default timings.
    EWF, HORM, MinLogon on XP.
    Zotac ION Atom N330, 2GB low-profile RAM, M3-ATX
    Win Embedded Std 2011 RC
    OCZ Vertex Turbo 30GB SSD
    Lilliput 629 Transflective, WRX Screen Mount
    BlueSoleil BT, i-Blue GM-2 GPS, DirectedHD Radio, Andrea Mic
    VoomPC 2
    Mar 2006
    thats good to know, i will be getting my zotac ion board tomorrow
    Constant Bitrate Ramb0_Command0's Avatar
    May 2006
    NW Pennsylvania
    I'm running a jetway mini-itx motherboard with a c7 processor, not sure what model exactly but I had to update my BIOS and change a setting in the BIOS in order to get the video card to display the 800x480 resolution. But after I got it working, the screen would be misaligned whenever it came back from hibernate. I had to turn the screen off and back on.
    I just stuck with 800x600.
    Car PC Project Status
    Audio......[====================] 100%
    Computer.[====================] 100%
    Car.........[====================] 30%
    <------ If my information is helpful, give me some rep! The scale thingy :)
    Oct 2006
    Bear, DE, USA
    I'm using a laptop (HP nc8230) on a dock (HP Advanced Docking station) using an ATI x600M to provide 800X480 60 Hz to my Zenarc 701 TSV, via one of the three powerstrip timing settings described in the "everything you want to know about your Zenarc" sticky thread...I will post powerstrip timings when I get the chance to look them up...I did have to tweak the horizontal frequency up one notch to get the monitor to lock on properly and consistently, but it works every time now.
    So:
    ATI X600M
    powerstrip -> Coffeejolt's settings on p.3 of the "everything...zenarc" sticky thread, only "up" one arrow press on the horz scan rate (top)
    Zenarc 701TSV
    = working 800 X 480
    I have too much time and too little aggravation in my life, so I built a carPC. ;)
  1. Replies: 9
    Last Post: 06-22-2005, 12:11 AM
  2. Frodo: Work Harder, Work Faster..
    By hevnsnt in forum FrodoPlayer
    Last Post: 09-24-2004, 04:09 PM
  3. Replies: 13
    Last Post: 09-02-2004, 02:57 PM
  4. Replies: 4
    Last Post: 11-18-2002, 09:59 PM
  5. question about resolution
    By steve671 in forum LCD/Display
    Last Post: 11-28-2001, 09:25 PM
