Results 1 to 5 of 5
Thread: gooddeals18.com screen, powering it
    Aug 2007
    Nice a forward title. I got the 8 inch screen from gooddeals18.com and I am now trying to figure out how to power it. Currently it is powered by its wall adapter. I have the m2-atx would I power that off of it, or what do I power it with?
    Maximum Bitrate bratnetwork's Avatar
    Oct 2007
    Haledon, NJ
    what does the wall adapter say that the output is? If it outputs 12VDC to the screen then you can power it off the M2
    Aug 2007
    Yes it says 12v/2a but how would I power it from the M2-ATX? Both of the molex connectors are occupied with my dvd drive and harddrive? Is there like a splitter molex connector I should look into?
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Quote Originally Posted by TexasAggie View Post
    it didnt come with a car apater? Yes there is a Molex Splitter. http://buyextras.com/powsplitcab4.html
    HiJackZX1 w/ The Tobiathin Core PC system!
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
    1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
    Starting Raspberry Pi multizone project.
    Jan 2008
    Norton, MA
    A y-adapter like linked above should do the trick for you, Cut the yellow wire to get your 12V and a black wire for ground, and extend them to the monitor. You should be able to cut the barrel connector and splice it together with the power+ground that you just extended then you will have a plug-n-play setup for powering the monitor in the car. This is how my 10.4" shark is powered, off my OPUS 320w works great.
    2005 Ford F-350 crew cab 4x4 6.0L SRW LWB
    Planning:
    [|||||||||-] 95%
    Parts Aquisition:
    [||||||----] 60%
    Install:
    [|||||||||-] 90%
    Finally getting Built
  1. 2007 Mazda 3 Dash Screen looks OEM
    By Splash-X in forum Show off your project
    Last Post: 05-04-2009, 06:29 PM
  2. Digital FX 2.0 Transparent Released
    By JohnWPB in forum RR Skins No Longer Supported
    Last Post: 03-07-2008, 01:23 PM
  3. 7" Dynamix (LinITX) LCD - white screen problem
    By xraycat in forum LCD/Display
    Last Post: 10-22-2007, 01:43 PM
  4. Constantly removing the screen 7" lilliput advice
    By steveb in forum LCD/Display
    Last Post: 04-17-2007, 11:56 AM
  5. Playing full screen video only to rear screen
    By yossisibi in forum Centrafuse
    Last Post: 10-29-2006, 07:06 AM
