well you need a decoder IC to take the reading and convert it to numbers. Check to see if you can use the chip that drives the voltmeter's LCD. From there you have to figure out what the pin outs are.
I forgot what IC you would need cause I only did it once in class, and you might have to look at some electronic stores to find it, not sure radioshack carries it anymore.
LinkBack URL
About LinkBacks
