Results 1 to 6 of 6
Thread: ELO Power Pinout
    Dec 2006
    California
    ELO Power Pinout
    Been searching and searching for what I would assume would be easy to find, but have had no luck. Just got my "new" ELO 15" touch (Model Number; ET1525L-7SWA-B) and it has no power cord, which was to be expected. Problem is I, being the *** that I am, assumed it used a standard monitor power cable, and it doesn't. So, I tore it apart, got to the board with the power connector on it, and there are 5 metal pins soldered to the board. Four for the four pins in the connector, and one for what looks to be shielding around the inside diameter of the connector.
    I figured I would find a pinout, and solder some wires to the underside of the board for power, but I can't seem to find a pinout for this thing anywhere. I could test and see which pins on the board coincide with pins in the connector, but I still wouldn't have any idea which were power and ground.
    So, if anyone can find a pinout, or tell me a way to determine which pins are ground/power it would be greatly appreciated.
    And if anyone wants a pic of it, I can take one. It kinda looks like the female end of this.
    Jul 2008
    Pinout
    two +12 vdc, and the other two are ground which is the same as the outer sheild. i'll post some sort of drawing and power spec later
    Jul 2008
    Part #451810-000. 12 VDC@5A 4 pin,1&2 +,3&4 - As your pic the top 02 are pin 1,2 and bottom pins are ground. and here is driver 4 it http://www.elotouch.com/files/unrest...s/SW600650.exe
    good luck
    Low Bitrate UniqelyCommon's Avatar
    Nov 2008
    Teh Internets
    Much thanks!
    Now the question is: is there a supplier of those mini-Din's...
    Radio Shack has never heard of them, my former boss uses plugs like that for his mini-DVR's (portable security camera trailers) and said they're expensive ($50) but I think he was including the 120VAC to 12VDC supply as well.
    Anybody know a good connector/plug outlet, erm, store?
    Jul 2008
    You can find the same plug on those external devices(Ext. DVD, NAS, or Ext 3.5 hard drive) but req'd some mod to it since this monitor take 2 12v dc not 01 12v, and 01 5v like those devices, or you can solder directly on to the PCB. Good Luck
    Nov 2008
    Teh Internets
    Right, that's my current plan (get it, "current"? ha ha ha...*ahem*)
    unless I can find a mini-Din of that sort
  1. FAQ: How do I power my DC-DC PSU on my workbench?
    By DarquePervert in forum The FAQ Emporium
    Last Post: 12-14-2011, 06:55 PM
  2. Replies: 115
    Last Post: 03-05-2011, 03:54 AM
  3. Finalizing Power Supply Options
    By Nstyle in forum Power Supplies
    Last Post: 04-01-2007, 03:40 PM
  4. Power Supply/OPUS Kill Switch
    By SpaceMonkey in forum Power Supplies
    Last Post: 08-11-2006, 10:58 AM
  5. Replies: 7
    Last Post: 06-15-2004, 09:29 PM
