Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: problem xenarc tsv 7'' vga monitor (4-wire)
  1. #11
    Maximum Bitrate customaudioman's Avatar
    Oct 2005
    east coast
    it just sucks that every time I turn my car on, it starts back at 33 on brightness. And since I dont have a remote, I cant set it. With the touch screen, it works sometime, when I touch the screen, it takes the cursor a few sec to come near your finger. it only high light the icon and never completes the command. is this common for the older 7tsv monitors?(4 wire) are the 5 wire 7" tsv xenarc monitor much better or the same issues? I dont want to spend another $350 for the same problems. Also I will be molding this monitor also.
  2. #12
    Newbie xenarctech's Avatar
    Aug 2009
    Quote Originally Posted by customaudioman View Post
    Your described problems are not common for the older 4-wire 700TSV. It is hard for us to tell without getting some more info on them (e.g. serial number, manufacturing date) and/or looking at them. It also could be anything from the way you mold the monitor to the age of the monitor. As you know, we have discontinued the 4-wire model for many years. The 5-wire 700TSV are years ahead of the 4-wire. We even revised the 5-wire 700TSV multiple times since it's introduction. The casings might look similar, but are actually completely retooled with various improvement including the material used. In addition, 5-wire is a superior technology to 4-wire. It last longer and is more responsive to the touch. Why don't you purchase and test a 5-wire unit before you take it apart and return it if you are not satisfied with it?
  3. #13
    Oct 2005
    east coast
    I will buy the new 5-wire one soon, kinda just waiting for this one to die... lol. The one I have is all black one not the silver 4 wire one. I will check my box for the # in a few days.thanks
  4. #14
    Feb 2006
    Dallas
    xenarctech Are you saying that the brightness setting is suppose to remain at it last setting when the unit is turned off? Every since I've had my 700TSV it has been the main complaint I have had with the unit, (the other being the resolution numbers and the input 2 stuff that pops up on the screen). I turn off the monitor to get gas, or run into a store and everytime I get back in the card the brightness has to be reset. This is hard because the unit is built into the dash and I have to try to locate just the right spot to use the remote to change it back. Why not just have options on the menu for saving the brighness and another option to display or not all the other garbage that pops up on the screen. I added a usb capture card so that I could use the backup camera without the "Input 2" or what it was that was always on the screen when I had the camera hooked up to 2nd input. It takes away from the professional look of the system with all that OSD clutter. Anyway i would like to update my xenarc to the higher brightness unit, if I can get the brightness to work properly.
    Walt
  5. #15
    Oct 2005
    east coast
    Quote Originally Posted by walttoinfiniti View Post
    Walt
    So do you use the newer 5 wire t/s 700tsv monitor? I have the older 4 wire one, but have the same problem with the brightness reset when the car is turn off.
  6. #16
    May 2006
    Calgary, Alberta
    I have the 5 wire 700TSV and my brightness saves itself more than 95% of the time. There's the odd time it'll for some reason go back down to 27 and it'll do it every time I remove the power source from the monitor.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
  7. #17
    Oct 2005
    east coast
    Quote Originally Posted by Maheriano View Post
    thanks for the input
  1. Replies: 4
    Last Post: 08-09-2007, 02:18 PM
  2. 8" Xenarc VGA Touch Screen LCD - $325 shipped
    By digitalww in forum Classified Archive
    Last Post: 09-08-2005, 11:15 PM
  3. WTS: Broken 7" Xenarc TSV - VGA Connector Broke Off The Board
    By jeeplaw in forum Classified Archive
    Last Post: 07-16-2005, 11:57 PM
  4. Resolution problem with Xenarc 700YV
    By lookinco in forum LCD/Display
    Last Post: 09-20-2004, 04:12 PM
  5. xenarc tsv touchscreen problem
    By icet in forum LCD/Display
    Last Post: 09-17-2004, 09:33 AM
