Results 1 to 10 of 14
Thread: LCD Brightness at night
    Aug 1999
    Washington D.C.
    I have major issues with blight LCDís lighting up the interior of my car at night. On most LCDs you can adjust the brightness, but at night at the lowest brightness setting is still relatively bright and annoying.
    What mods can be done to fix this? Perhaps turning off one or more of the backlight tubes?
    How about the big boys like Lexis or Infiniti address this problem with their navigation systems? Iím sure their screens arenít lighting the whole interior of their cars up at night.
    Maximum Bitrate jzgt's Avatar
    Mar 2002
    What about an OSD? Wouldn't that control the brightness?
    As far as OEM Navigation LCDs, that is a good question...maybe it works off of the lights. If the lights are on, the LCD is dimmed. I'll have to look into that...
    - Jeff
    Aug 1999
    Washington D.C.
    Originally posted by jzgt
    [B]What about an OSD? B]
    What is OSD?
    Mar 2002
    On Screen Display - Most Controllers have them availible. I have heard of people just hooking up a POT to it. I'd like the ability to dim the screen too...I don't know if the OSD would do what we're trying to achieve. I think Leslie had an OSD with his DennisK setup. I haven't seen Leslie on the board in quite some time.
    - Jeff
    Sep 2002
    Redmond, WA
    Sometimes a video card / driver will have gamma settings. You could possibly pull down the level a bit for night driving.
    Try installing powerstrip http://www.entechtaiwan.com/ps.htm, and then look under Color Profiles - > configure. You might be able to adjust brightness and gamma.
    It's possible these features only work \with 3D cards, but its worth a try.
    I tried it with my laptop and it worked great, but I have GeForce 4.
    ddt
    ddt is offline
    FLAC ddt's Avatar
    Aug 2002
    - Jeff
    How exactly (be specific here ) would one do that? This might be just what I need to do.
    Sep 2002
    Redmond, WA
    I assume this means dialing the backlight inverter voltage up/down with a potentiometer?
    This sounds a little dangerous if it is on the output side since we're talking hundreds of volts. Danger. Danger. :-)
    Sep 2002
    Austin / Houston TX
    I'm a dumbass when it comes to electronics (well..for now I am) but:
    Don't you just hook up the pot to the power lead of the backlight? Then it would just vary the amount of power going in. How would you knwo what type of pot to get (are they rated by current or voltage, etc)?
    Or not? Someone please come educate me.
    No Carputer YET.
    A car I'm designing...
    Sep 2002
    Redmond, WA
    well, assuming it works, decreasing the input voltage to the inverter would be much safer since you are only dealing with 12v or less.
    Sep 2002
    Austin / Houston TX
    Ahh sorry, I think you posted faster that I did...
    Lets say (hypothetically) that I don't know what an inverter looks like. Would it just be some box right before the backlight? What would you do with the negative side?
    Oh, and thanks BTW.
    No Carputer YET.
