Results 1 to 10 of 14
Thread: Hardwire car sound so it will work throguh the xenarc?
    Aug 2002
    Delaware
    How would u hardwire all your stock speakers so they will play mp3's throughout the whoel car instead of just through the xenarc speaker?
    please help
    matt
    Sep 2002
    Just North of Toronto, Ontario, Canada
    You need to run the sound through your headunit or an amp. to get the sound into your headunit, you need to use either aux in, an FM modulator, or a tape adapter.
    there has been much discussion of all the pros and cons of each of these methods, as well as hooking up an amp, so a quick search will be faster then getting people to type out all the pros/cons.
    Project AutoBoxen: Coming along, almost ready to hook up in the car.
    Celeron 500, 192mb ram, 8gb hdd, other stuff.
    '91 Mazda 626: Its free, so ill use it.
    Aug 2002
    Delaware
    ok well if i ran my sound card to my amp..the amp would have to run to each speaker right?? i dotn want a headunit..the point of this project was to get rid of the headunit..how would i hook up a fm modulator?
    Feb 2003
    Long Island, New York
    If you search the forum you will find alot of ways to hook up your carputer to your audio system. If you are not going to use a head unit then you can use an FM mod or connect through the aux in, because they only work when hooking up to a head unit. Somehow you have to hook up your sound card directly to your amp, but I'm not too sure as to how to do it. That way you won't need a head unit and you can use the computer volume control. Maybe someone else can fill in where I left off.
    Oh yeah and when you hook up your sound card to you amp the amp would power the speakers, not the sound card. THe sound card would just decode the information for the amp to send to the speakers. I think that is what you were asking.
    Maroon Monte Carlo In process of Being Pimped Out.
    ddt
    ddt is offline
    FLAC ddt's Avatar
    Aug 2002
    sound card-------->mini to RCA "Y" Adapter----->Amp------->Speakers
    Mar 2002
    [QUOTE]Originally posted by ddt
    sound card-------->mini to RCA "Y" Adapter----->Amp------->Speakers [/QUOTE}
    bingo
    Aug 2002
    Delaware
    mini to RCA "Y" Adapter what is that..where can i buy it and what does it do? what channel amp would i need to power to front speakers and 2 rear speakers.....so i would not need anything else..jsut what u stated..from the sound card to the rca "y" adapter to the amp to the speakers?
    what do i search for on the forum one how to do this many differnt ways?
    ddt
    ddt is offline
    FLAC ddt's Avatar
    Aug 2002
    you can buy them @ radio shack
    and yes... that's all you need
    Aug 2002
    Delaware
    OK what is the minimum amount of watts i would need to power all 4 speakers and how many channels would i need?
    Jan 2003
    Ruston, LA
    What type of speakers ?
