Ok, I figured out the problem and this infomation may help others:
The VGA connector that comes with the monitor is wired differently on the 15 pin D-Sub side than it is at the PCB.
For example the grey wire on the PCB side is for horizontal sync but if you cut the wire from the D-Sub side of the cable, before the 9-pin DIN connector (as I did) and check which pin grey is connected to with a multimeter, it's actually connected to pin 1 of the D-Sub which should be for Red in the RGB signal.
This is really confusing and it seems as though the wires must be swapped round in the 9-pin DIN connector or something?
Anyway it's working now...
LinkBack URL
About LinkBacks
