Results 1 to 5 of 5
Thread: lilliput 629 - no input signal problem
    poz
    poz is offline
    Aug 2008
    hello,
    i had a lilliput 629 touch screen in my car with a running carpc,
    i decided to upgrade it to a new pc:
    motherboard: gigabyte GA-G31M-ES2L with intel cpu
    psu: m4 250W
    memory: 1 gigabyte
    i tried to run it at home and it worked great.
    i tried to run it at the car and i got:
    black screen, and then "no input signal" msg and then black screen again ...
    endlessly.
    i tried to connect a laptop to the vga cable and it worked great too.
    so the cables are good, the screen is good, the pc is running on a normal screen at home,
    what im doing wrong?
    thanks, nir.
    Variable Bitrate billmee's Avatar
    May 2005
    USA
    Do you get any thing on the lili.
    Menu?
    VGA no signal message?
    Apr 2009
    Quote Originally Posted by poz View Post
    hello,
    psu: m4 250W
    memory: 1 gigabyte
    endlessly.
    thanks, nir.
    I just had this problem. You need to really shove the video wires together. I mean literally as hard as possible.
    poz
    poz is offline
    Aug 2008
    but i used a laptop connected to the vga from the back of the car until the screen and it worked just fine,
    its not enough to know that the connection is good?
    where do you mean to really shove it, on the motherboard itself?
    poz
    poz is offline
    Aug 2008
    problem sovled!
    it was the vga connector that connects to the pc itselfs
    i pluged it again and closed it with the the screws
    and it works!
    thanks for your help!
  1. Need Help: Lilliput No-Input Signal
    By Cdeldridge in forum LCD/Display
    Last Post: 10-01-2012, 05:14 AM
  2. lilliput 629 Touch. flickering problem
    By LiCelsior in forum LCD/Display
    Last Post: 11-05-2008, 12:14 PM
  3. Lilliput 629 -- broken, or am I dumb...?
    By spamminator in forum LCD/Display
    Last Post: 06-29-2008, 11:46 PM
  4. lilliput 619 is reflective, 629 has antiglare?
    By kbyrd in forum LCD/Display
    Last Post: 06-23-2006, 08:44 AM
  5. Media Car not responding... Lilliput problem?
    By carpcnoobie in forum MediaCar
    Last Post: 09-01-2004, 02:38 PM
