Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: EBY701 power help
    Jan 2005
    EBY701 power help
    ok I have a EBY701 and it is acting really odd it i turn it on the will act like it is coming on but doesn't display anything or as soon as power comes on it will simply start flashing the red power light both problems just started I have it running from a 800MA generic 12v regulator as i can't locate the egg that came with it and it puts just enough pull on the PSU that the motherboard won't post
    any ideas on the lcd would be great
    Thanks,
    yonu
    Jul 2008
    So that's definitely a power problem. Sounds like it could be one of 2 problems: input voltage and/or output voltage too low. For input I mean, if the car battery is fairly drained and not providing enough voltage to the regulator then you'll have a low voltage output on the regulator. Similarly if the regulator is not properly rated for the screen, even if the battery voltage is ok, you have the same problem. When this happened to me before, the screen would initially show some life, but there would not be enough power to keep the lcd powered. I troubleshooted this using a multimeter and off I went.
    It makes sense that this may be a car battery problem if your MB won't post. The power for the screen is not drawn from the MB, as the usb is only for the touchscreen controller. If input voltage is off then your MB PSU wouldn't provide enough power.
    A multimeter is your best friend for your problem. Use that to test voltages at the various points and you'll be good.
    Jan 2005
    what is the rating on the egg that comes with the 701 i just got done playing with it the voltage is fine i thank it is a ampage issue as when it kicks on the adapter i have on it flickers off then back on
    Jan 2005
    I just stubled accross the egg for my 701 but i now remeber why i had throwed it in the drawer wiht old parts the caps in it had blown
    Jan 2008
    Dartmouth, MA
    The power adapter you have, may not have been designed for constant use and could have worn down to the point where it is no longer supplying the rated amperage. Also, the temperatures are getting hotter out, so the efficiency of everything is going down and everything could be wanting more amperage and at the same time, the adapter may be providing less amperage. I checked my EBY 701 a while back with a multimeter, and remember it sucking in about 700 mA. It jumped up higher during turn on though. I would test it using some other power supply or maybe bring it in the house and run it off a normal PC's power supply just to test it out and figure out if power is really the issue.
    My Nearly Complete Car:
    http://www.mp3car.com/vbulletin/show...ed-car-pc.html
    Micro Control Center... Control Your Car Across the Internet
    http://www.mp3car.com/fusion-brain/1...-internet.html
    Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
    http://paulfurtado.com/
    Jan 2005
    well i did try the AC brick that I used to get it when I was molding it into the panel and it does the same thing it will work a couple times then it won't the most common thing I am noticing is the power led on the screen blinking on and off slowly
    any thought
    Jan 2008
    Dartmouth, MA
    how hot is the room you're working in?
    It's sounding more like a problem with the screen though...
    Jan 2005
    about 70f and it was working fine the last time i had power to it which was about a month ago(had to wait on some parts)
    Jan 2008
    Dartmouth, MA
    Yeah 70 degrees wouldn't be an issue. If you said 120 degrees in a hot car, we would have nailed it =). How many mA does the AC adapter output?
    Jan 2005
    250ma also i just finished checking the board and couldn't find any blown components
  1. Replies: 115
    Last Post: 03-05-2011, 04:54 AM
  2. Hardware Review: M3-ATX Power Suply
    By Bimmerstyle in forum The Review Palace
    Last Post: 03-05-2008, 06:57 PM
  3. fried my carnetix power supply?
    By mustanglou in forum Power Supplies
    Last Post: 11-10-2007, 12:34 PM
  4. N00b Power Question
    By jamiewhittingha in forum Power Supplies
    Last Post: 03-25-2005, 01:08 AM
  5. Replies: 7
    Last Post: 06-15-2004, 10:29 PM
