+ Reply to Thread
Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Xenarc 702TSV torn flex cable after custom fit
    Constant Bitrate STI_FFY's Avatar
    New Market, MD
    I bought a 702TSV to replace the old Lilli in my Subaru's dashboard. The reason for the replacement was that the old Lilli was never very easy to see, and the touchscreen has started to fail lately. Sometimes touching the screen does not move the pointer at all or moves it to a point very far from where touched.
    The 702TSV is incredibly bright and all my testing so far shows it to be far better than the original Lilliput (which was not transreflective).
    Of course I had to modify the display to fit it into the double-din opening in my STi's dash. Now the Xenarc LCD panel snaps into the STi dash from behind.
    Anyway, after taking it apart many times and putting it back together for intermediate testing, it failed the test yesterday. The colors were all screwed up. I first verified that this affliction applied to all 3 sources - VGA, AVI2 and internal menus. The most likely candidate for this collection of symptoms was the flex cable.
    It turns out that in the disassembly process I overstressed the flex cable that connects the controller to the LCD panel. It has a short tear through pins 1-4 of this 50-pin flex cable.
    Be careful with that cable! It cannot be replaced apparently. I had to buy a new LCD panel @ $190 plus shipping in order to fix this.
    Fortunately for me Xenarc are very good about selling parts.
    It's very sad that now I have this perfectly good and very bright LCD panel that cannot be used for want of a few conductors on this cable. If the other end was removable this would be a $10 fix.
    I tried to repair this by jumping the gaps with fine wire, but there's no soldering tip on earth thin enough for this job - at least not when wielded by me.
    SeeYa! -Jim-
    Low Bitrate SwiftDeath's Avatar
    Apr 2009
    Chicago, IL
    Wow that's rough. I suppose it's good you posted this as it's good to know how strong, or in this case fragile, certain components are.
    -SwiftDeath
    New Market, MD
    It seems to be very difficult to slide the cable out once the black plastic bail has been lifted on the connector. With no pull tab or block on the cable it is necessary to pull on the cable itself. It is difficult to pull without exerting uneven pressure and one end of the cable will get stressed.
    When the new one arrives, I will consider gluing a pull block onto the cable so it will be easier to get it out of that connector when need be.
    SeeYa! -Jim-
    Jan 2008
    Dartmouth, MA
    Have you tried shaving the plastic off of the wires? If you used a knife and shaved the plastic off of the ribbon in that spot, you might get enough room to solder it.
    My Nearly Complete Car:
    http://www.mp3car.com/vbulletin/show...ed-car-pc.html
    Micro Control Center... Control Your Car Across the Internet
    http://www.mp3car.com/fusion-brain/1...-internet.html
    Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
    http://paulfurtado.com/
    New Market, MD
    The insulation isn't the problem. The spacing between the wires is.
    I got the copper exposed using an emery board. I actually managed to bridge pin 1, but when I tried to bridge pin 2, the bridge on pin 1 came undone (the iron touched it briefly). Also the jumper wires are so short that when you touch one end, both come unsoldered and the wire shifts.
    I suspect the only way to be successful would be to have several wires spaced the correct distance and solder them all at the same time. I have not yet come up with a way to do this.
    I haven't given up. I've thought about taking an old surface-mount chip and using its legs. I'll need to find one with the right spacing and long legs.
    SeeYa! -Jim-
    Vendor - Qube colin's Avatar
    Dec 2006
    Try using solder paste and a heat gun on very low air pressure on just that spot. The syringes that they provide you with are ridiculously small and with wet enough solder you could fix that for sure. If not, sell it to me for super duper cheap and Ill make it work
    New Market, MD
    Quote Originally Posted by colin View Post
    I think the problem with that approach would be lack of structural strength. The moment it flexed the solder would crack. You need some wire across the tear for rigidity.
    SeeYa! -Jim-
    Dec 2006
    Well im assuming the black (darker) part doesn't flex? I would just coat that part in epoxy and not let it flex. There's no way that a 1mm difference in where the cable can and can't flex would affect performance. Youd basically just be extending the rigid connector area.
    Feb 2006
    Melbourne, Australia
    Would you consider selling that LCD then? I could fix it, and have a need for just an LCD -> will run LVDS onterface off my motherboard to it...
    Would appreciate your feedback.
    F6 Tornado Project Log ; HP Blackbird Watercooled Server
    Beta Tester for Centrafuse and 3dConnexion (No business affiliation with either)
    New Market, MD
    Quote Originally Posted by mrbean_phillip View Post
    I'm not really interested in selling it. I plan to devise some way to fix it. It may take some time, but there's got to be a way.
    SeeYa! -Jim-
+ Reply to Thread
  1. Replies: 8
    Last Post: 04-29-2008, 08:56 PM
  2. xenarc ribbon cable
    By villybhakta in forum LCD/Display
    Last Post: 06-18-2007, 03:24 PM
  3. FS - Custom made Xenarc Bezel for 05+ WRX/STi
    By RR BuGGz in forum Classified Archive
    Last Post: 09-13-2005, 03:33 AM
  4. WTB LCD/TFT monitor that will fit in xenarc shroud
    By lostreception in forum Classified Archive
    Last Post: 08-17-2005, 01:51 PM
  5. Does Xenarc use a DFP to VGA cable?
    By Player_One in forum LCD/Display
    Last Post: 11-08-2004, 04:27 AM
