Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 38
Thread: Custom Intel 945GM Drivers for Lilliput EBY701 - Native 800x480
  1. #11
    Dec 2008
    --- "I just need to change the scan frequency and adjust the front and back porch on the vertical scan." So I fiddled with the numbers until it worked perfectly...
    What tool you were using to see if the setting is right? Powerstrip or just re-install the driver on each retry?
  2. #12
    Low Bitrate AvWuff's Avatar
    May 2008
    Quote Originally Posted by efun View Post
    Reinstall each try. Luckily, my guesses were pretty close and it actually worked perfectly on my second try :-)
    -av
    Read about my Car PC at www.avbrand.com/projects/carpc -- LED sign now functional!
  3. #13
    Dec 2008
    I think it is to modify the windows registry. If so, both DTD caculator and make a .reg file will work too, right?
  4. #14
    May 2008
    I suppose, but DTD calculator's "apply" option didn't work for me. That's why I reinstalled the driver each time.
    -av
  5. #15
    Dec 2008
    After many retries, I got it finally
    The dirver is just yours at first post, the point is I must delete the device before install the driver for it, or the LCD just keep black or said "NOT SUPPORT". Once the driver install sucessfully, the display was 800x480 but not point to point with the LCD. I use the LCD auto adjust function to make it point to point.
    Now the display was perfect, but has a problem. When I unplug and reconnect the VGA harness, the display will be incorrect. Need reboot windows to solve it. Forunately, there will be a little chance to unplug the VGA during windows running.
  6. #16
    Mar 2009
    near Rochester, NY
    Any idea if this would work with a 629 (non-LCD version)? Or is there any harm in trying? Or if all you did was change the DTD, should I just try that DTD instead of the one I am currently using?
  7. #17
    May 2008
    Hiya,
    No, there's really no harm in trying. It'll either work, or it won't. Just make sure you have a way to get back into the PC to roll back the driver, such as via VNC or Remote Desktop.
    -av
  8. #18
    Dec 2008
    Yes, if the setting are incorrect, the sreen will be blank. you can enter the VGA or safe mode to restore the driver back.
  9. #19
    Jan 2006
    Quote Originally Posted by AvWuff View Post
    Hi guys,
    After many hours of futzing around, I finally got my Lilliput EBY-701 to work perfectly with 800x480. I've modified these newest Intel drivers for the 945GM chipset to add that resolution as an option.
    Hope it works for you, Enjoy!
    Wow, thanks a lot for doing this!! I've been waiting probably 3 years for someone to come out with drivers that allowed native 800x480 on our stupid 7-8" 800x480 screens for use on the embedded chips. My workaround has been installing a PCI video card that would support 800x480 with powerstrip hacking, but this necessitated a large case (shuttle small form factor) to get the 2 PCI slots I needed. A while ago, someone posted similar drivers, but they blue screened Windows when you tried to use hibernate - useless.
    Can anyone else confirm the drivers worked in their configuration?
    SG
  10. #20
    May 2008
    Hey Smelly,
    I suggest you try them -- but even if they don't work, you can take the steps I took to make your own Intel drivers.
    -av
  1. Intel 865 custom drivers
    By neilwozau in forum LCD/Display
    Last Post: 07-02-2010, 12:52 PM
  2. Shuttle sv24 or fv24
    By michael_16j in forum General Hardware Discussion
    Last Post: 06-05-2006, 03:56 PM
  3. 800x480 on Intel 845, some hope?
    By sama in forum LCD/Display
    Last Post: 03-10-2006, 03:25 AM
  4. How is this motherboard? Intel board inside..
    By sspiro in forum General Hardware Discussion
    Last Post: 01-16-2005, 02:16 PM
  5. Replies: 3
    Last Post: 10-22-2004, 12:09 AM
