Results 21 to 30 of 38
Thread: Custom Intel 945GM Drivers for Lilliput EBY701 - Native 800x480
  1. #21
    Low Bitrate ZoLtRiX's Avatar
    Nov 2002
    Niagara Falls, Ontario
    sweet thanks, just installed it and it works great!!!
    good job
  2. #22
    Jan 2006
    Quote Originally Posted by AvWuff View Post
    Hey Smelly,
    I suggest you try them -- but even if they don't work, you can take the steps I took to make your own Intel drivers.
    -av
    Oh, one of these days I will when I "upgrade" to a smaller box with embedded graphics. My problem is that everything works okay now and the enemy of good is better.
    Quote Originally Posted by ZoLtRiX View Post
    good job
    cool! Which mobo and LCD screen did you try it on?
  3. #23
    Nov 2002
    working good on my D945GCLF MB and EBY701
    Quote Originally Posted by smellygas View Post
  4. #24
    Dec 2006
    Austin, TX
    Has anyone gotten this to work with a 629GL (2008 LED backlight version)?
    I have a 965GM and am running linux, but I would like to know if it is at least possible for the 629 to actually display this resolution (in any system). I always assumed it was impossible, based on the other threads here.
  5. #25
    Jun 2009
    Unhappy Samsung q1 ultra NP-Q1u
    Hi all ,
    scuse me for my english but our language is a big problem for me.
    I'm a new menber of forum .
    I have a big question : i have a samsung q1 ultra LCD Touch 7" 1024x600 eqipped with intel M945 express chipset is possible to force graphic card on 800x480 ?
    The solution posted to other menber not work in my case , after restart windows xp set resolution on 800x600 or native LCd resolution 1024x600.
    In control panel graphic card not list 800x480 in resolution supported.
    Please help me .
    Thanks regard
    Override
  6. #26
    Low Bitrate AvWuff's Avatar
    May 2008
    If the native resolution is 1024x600, why would you want to run it at 800x480??
    -av
    Read about my Car PC at www.avbrand.com/projects/carpc -- LED sign now functional!
  7. #27
    Jun 2009
    Q1 ultra
    Thank 's for your interest .
    I use q1 to run special gui software designer for vantagecontrols inc .
    this software support designed gui only on 800x480 or 1024x768.
    Vantage controls touchscreen 7" ( 800x480) have a big prize 2500€ , touch 10 "
    ( 1024x768 ) have this price 3200 € , if is possible to set q1 ultra on 800x480 ,prize of my prject is too low , and q1ultgra ,have many plus functions , and too high performance .
    Excuse me for my spghetti English I'm italian
    Thank's Best Regards
  8. #28
    May 2008
    Quote Originally Posted by override View Post
    Wow, I don't think I've spent that much on my home automation setup, and it probably does way more than Vantage does, www.avbrand.com/home
    -av
  9. #29
    ptk
    ptk is offline
    Singapore
    just a quick note that I used the same technique to modify intel's driver for GM45 and got it to work on windows 7/32bit with lilliput 629
    CarPC Ver 4 completed. Aopen i45GMT-HD, C2D mobile 2GHz. Photofast 64GB SSD. Novatel EU-850D
  10. #30
    Sep 2008
    Av, thank you very much for this driver - it seems to be finally working for me with my D945GCLF2 and EBY701.
    But could you please clarify, what frequency is it supposed to be running at?
    60Hz didn't work for me - the Lilli detected it as 800x600, and showed the image with black borders. The funny thing was that when I switched to 800x600 it detected it as 800x480, and it was scrolling. This was crazy.
    Finally I found 800x480@55Hz in the list, tried it, and it worked!
    Now I'm not sure if it is OK to keep this mode - won't it hurt the monitor?
    When I was playing with PowerStrip, at some frequencies the monitor kept switching off and back on every second - neither it nor I liked that, and now I'm afraid if it could happen again with this non-very-standard mode.
  1. Intel 865 custom drivers
    By neilwozau in forum LCD/Display
    Last Post: 07-02-2010, 12:52 PM
  2. Shuttle sv24 or fv24
    By michael_16j in forum General Hardware Discussion
    Last Post: 06-05-2006, 03:56 PM
  3. 800x480 on Intel 845, some hope?
    By sama in forum LCD/Display
    Last Post: 03-10-2006, 03:25 AM
  4. How is this motherboard? Intel board inside..
    By sspiro in forum General Hardware Discussion
    Last Post: 01-16-2005, 02:16 PM
  5. Replies: 3
    Last Post: 10-22-2004, 12:09 AM
