Results 1 to 5 of 5
Thread: Inverter for LQ104V1DG11
    Mar 2003
    Hey guys, first post... been reading and searching a lot... I am getting a LQ104V1DG11 (I hope). I saw this inverter... will it work?
    Inverter for: Sharp LQ133X1LH62 and LG.HILIPS LP133X7 13.3" TFT LCD Screen
    Model: DAOHS1IV6E7
    Mfr: HannStar
    samr
    I've got no answer! Question's Avatar
    Jan 2001
    Austin, TX
    Well the important thing is the voltage...check the LP133X7 or LQ133X1LH62 voltage and compare it to the sharp screen....
    probably not, though...so just bite the bullet and order one from Miles Industrial Electronics...I did and it works beautifully. http://www.milesie.co.uk/asp/product...roductcode=LCD
    ddt
    ddt is offline
    FLAC ddt's Avatar
    Aug 2002
    go to http://www.ergpower.com. They have just about every inverter for every screen.
    Maximum Bitrate jzgt's Avatar
    Mar 2002
    I did a quick google and found the following recommended inverters:
    TDK - CXA-0217
    ERG - Lists a couple - probably should call them but here they are:
    These are 5v and 12v inputs respectively:
    E1955, E1950
    K1906, K1918
    That info is available on their site at:
    Cross Ref
    MicroSemi lists a couple, too:
    LXM1622-05-02
    LXM1621-02
    LXM1622-12-02
    LXM1623-05-41
    LXM1623-12-41
    Taiyo Yuden Lists:
    KBI-B02D
    LS520A5 (5V Input)
    Hope this helps...
    - Jeff
    Sep 2001
    I have that screen and I use the TDK - CXA0217.
