If you mean flip the left to right when in reverse, All you need is to hook into the reverse circuit of your car "Example reverse lights" and then interface that into your computer via some like FB or any other method of input.
Then have the software monitor that input and when it becomes active, have a display driver level switch flicked which will do a screen flip. Depending on what software you are using for the reverse cam you can use a filter/image swap on that before it is displayed.
LinkBack URL
About LinkBacks
