Results 1 to 8 of 8
Thread: help wiring a capacitor to filter noise
    kuo
    kuo is offline
    Variable Bitrate kuo's Avatar
    Jun 2003
    Greensboro, NC
    with the help of the information in this thread i successfully hooked up my xenarc's brightness control wire to my car's dimmer knob. because my car's dimmer knob outputs from 0V to 12V and the xenarc's brightness control wire only goes from 0V to approximately 3.7V, i wired up a voltage divider to get into the desired range as follows.
    the problem i have after doing this mod is that i get rolling lines in the screen whenever i dim the backlight using the knob. when i dimmed the screen using the lcd's menu i didn't get lines. Also the interference was present before i wired in the resistors, so the interference is definitely coming from the knob. i tried to wire up a capacitor to filter out the noise but i had no idea what i was doing and all i did was screw things up so i took the capacitor back out. i've done a lot of googling and reading here on the forums for guidance on how to do this but i'm still at a loss. can anyone tell me if i'm even on the right track with the capacitor idea, and if i am, what kind of capacitor do i need and where do i put it into the circuit? when i tried to wire it in, the dimming did not work at all and stayed at full brightness with output at 0V so i was obviously doing it wrong.
    my car: 2003 g35 coupe, 2.5ghz c2d cpu, gigabyte micro atx mb, dsatx
    wife's car: 2004 honda accord coupe 2.4ghz p4 cpu, asus micro atx mb, opus 150
    company car: 2006 chevy avalanche 2.0ghz p4 laptop, cnx p1900
    May 2008
    Is your dimmer really outputting a lowered voltage or is it pulsing the output (ie. producing a square wave with varying duty cycles)?
    kuo
    kuo is offline
    Jun 2003
    Greensboro, NC
    how would i go about figuring that out?
    i was also thinking...i have one of those noise filters from radioshack. could i wire that into the circuit somehow?
    kuo
    kuo is offline
    Jun 2003
    Greensboro, NC
    so i got some smaller ceramic caps wired in but i still have noise. i'm stabbing in the dark here since i know very little about the physics involved in all of this but my next move is to try bigger resistors in my voltage divider. i'm thinking since this is just a signal wire maybe i've got too much juice flowing...
    Constant Bitrate Pathos's Avatar
    Jun 2004
    St. Louis Mo.
    Is your dimmer the rheostat type or is it digitally controlled?
    "A rose by any other name is still a flower"
    May 2008
    Quote Originally Posted by Pathos View Post
    Which is the same question I asked and it really needs to be answered.
    If it's a rheostat lowering the voltage then you should be good and won't need a cap.
    If the output is pulsed, then no amount or type of capacitor will do what's requested.
    kuo
    kuo is offline
    Jun 2003
    Greensboro, NC
    i have the service manual for my car but it doesn't say anything about the dimmer being a rheostat. i googled for a while and found a few instances of people calling the dimmer a rheostat but nothing definitive...could be people just making assumptions. is there a way to test the dimmer to see if it is a rheostat or not? i have a cheapo multimeter.
    Vendor - Qube colin's Avatar
    Dec 2006
    For the most part, dimmers in cars are simple rheostats with voltage from 0-12v measuring in 255 bits. Your car actually knows how far your dimmer is turned, although it doesnt need to.
    The xenarc display is probably using a square wave pulse to control the lighting. Both LEDs and CFFLs are hard to control with varying voltage.
  1. Elminating line level noise
    By spoonraker in forum General MP3Car Discussion
    Last Post: 10-10-2011, 11:12 AM
  2. Noise Problem(Yes I saw the sticky)
    By diablodemorte in forum Car Audio
    Last Post: 10-04-2006, 06:16 PM
  3. Noise from my inverter .. Filter ?
    By Frog_boy in forum Power Supplies
    Last Post: 08-14-2006, 06:23 AM
  4. need some noise help
    By spyhunter in forum General MP3Car Discussion
    Last Post: 07-20-2003, 11:20 PM
  5. Specific wiring schematic 4 Optrex DMC40457?
    By sooty in forum LCD/Display
    Last Post: 07-17-2001, 03:11 AM
