Here are a couple more pictures - first is of the entire back with a couple of the controller boards removed, the second is of what I think is the affecting portion of the cable to the LCD...
Tonight I finally got around to taking my screen mount off my car to do some maintenence to the bracketing I have around the screen to keep it in place and ever since I did that I have this 1/4 section blacked out and with vertical lines. The lines have changed places at least once since this happened, but I can't figure out what is causing this issue. Does anyone have good ideas? I tried messing with almost all the wires on the screen with no change. I don't think I even touched any of the controllers when this happened - maybe it touched something and got shocked?
Carputer Progress:
Re-do fabrication of screen [DONE]
Add mini-USB and micro-USB power from M2-ATX [DONE]
Teardown PC [100%]
Add HDMI > VGA converter [0%]
Carputer Progress:
Teardown PC [100%]
I think this problem may be due to one of the cables being loose between the screen and the VGA cable - will try and remedy it tomorrow.
Carputer Progress:
Teardown PC [100%]
I'm sorry to tell you, but it's beyond repair.
From my worklog:
I looked under microscope, and the broken circuits that should be reconnected, are 20 microns wide, several times narrower than the tip of a needle.
You can't even replace the damaged flexible circuits, as they are glued to the glass.
^ditto - well no microscope, but it is the actual screen - and not something you can deal with by hand
start looking for a new screen
03 Hyundai Elantra GT {Worklog}
HP TC4400; 250GB SATA, WiFi, BT, 12.1" touch
RideRunner; w/ mobilephone.net, OBDMPG, mp3art, RRMedia
cmdRR tall skin creator
86 Pontiac Fiero SE 2m6
eventual carpc install
Yeah, I already started doing that - thought it was busted, but thought I would give it a shot anyway. Good thing there is a Xenarc 10.2" widescreen now that should work![]()
Carputer Progress:
Teardown PC [100%]
