That is an excellent build I love it. Well done Fusion-One
Yep
That diagram is exactly how I connected mine, and it works great.. I just lopped the end off of my rca cable, and soldered the wires directly.. insted of leaving the fat connector on.
When I was running VGA (in black and white) on the screen, I found it to be slightly clearer.. fonts seemed a little crisper.. but were still too difficult to read. For everything else, though. I noticed no difference between the vga and ntsc.. I dunno how anyone could on such a small screen.. :P
M-Pro-
So do you output a sompletely different signal to your 5" lcd? if so, how?
90% Done
60W DC-DC & shutdown controller
Via C3 800, 512mb Ram, HDD 75GB IBM Deskstar, 5.6" In dash Dcustoms LCD w/ 3m USB Touch setup
Rockfors 400s 400W amp,2x 10" Rockford Subs, Sony CDX M730 Head unit
All in a shiny White 2000 V6 Mustang
Click here to visit my NEW PhotoAlbum
Fusion:
How do you invert the picture?? Did you somehow turn the whole lcd upside-down inside the case?
Originally posted by ob1
Fusion:
Bingo, it was very easy to do. took me less than 5 minutes. no modding at all.. just undo screws, flip screen 180 degrees, screw back in place.
Can u clarify ?
Hi Fusion. I'm using a 5.6" Interact screen, exactly the same as yours. Trying to get it to work using a Ati Rage Fury pro video card, which seems to support that 480i arcade mode. I've used exactly the same wiring as in M Pro's tutorial, and i can't get it to work. Can u explain exactly what u mean by using the ntsc signals on the composite cable ? I'm confused.
U keep that original wiring from the VGA to the LCD, and u connect the Composite on your video card's TV-Out, and on the Sync and Ground on the board ? I'm lost, please help
Thanks in advance.
Cheebster
Cheebster, Fusion is not using the VGA mod. He originally did it so that he could use the AV switch in the back, but found out that he could just use the composite signal and ground from a normal AV cable. There is a picture that I posted 2 or 3 posts above that shows what he did. I also was confused and made the pic so that it could be clarified. Hope it helps.
Alright, thanks for the quick reply. But i'm still hoping to be able to make that interact screen to work with vga input... If anyone managed to get it work, please let me know, thanks !
08-09-2003, 04:45 PM
#100
Originally posted by Skraggy_uk
Tom, I'm pretty sure that with A Matrox card, and some of the TNT ones, plus Powerstrip, or some other detailed display settings prog (like the ones that actually allow you to change chip registers), you can change the synch frequency etc as well.
Has anyone gotten Powerstrip (or something similar) to work on a VIA ITX w/ CLE266 graphics chip?
Pv
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
