I got a NTSC Sony made Psone LCD Screen, since I cannot see any of the picture of this thread, I resume the procedure to this, do I miss anything ? Am I right ?
Can i Use this cable as my vga cable ? If im right the needed wire are already there.Quote:
Really all you guys are going to need for this mod is this LCD screen and a 270r resister
And an old VGA cable
I took the RGB from pins 1,2,3 on the VGA card and connected them to RGB pins 9,11,12 on the LCD
Then I took the H sync and V sync pins 13,14 on VGA and joined them together and then connected them to pic 6 on the LCD
Obviously I connected ground to pin one
And last but not lest I connected a resister to the red input then I connected the V and H sync to the resister.
Set the card to run at 15hz and that was it
http://www.lifemayhem.com/vga.jpg
