have you checked that Everything is earthed properlY.
I should have checked the reuired length before I started really, Oh well, could always buy another 2m or 4 metre cable to extend if needed. I can loop any leftover under the rear seat if needed.
Re: Earthing
I am wondering that but for the opposite reason.
On my 2001 Celica they have rear trays in the boot which is what the carputer is built into and hence it quite easy to take indoors.
When I built it indoors, I checked two composite phono cables and neither had any interference on the screen. When its installed in the car and when either cable is run down the car to the front on the opposite side to the power, I get interference from the HDD. Took the whole tray back indoors and its fine again. So the interference only occurs when its mounted in the car.
The only thing I can think of is that the earth return on the car is effectively the shell of the car and hence its acting as one big aerial??? The other thing is the power source is a 240v/300w 12DC -> 240V/300W AC invertor in the car and mains in the house
I am hoping that a Triple screened VGA cable is going to suffer less
Anyway this is going off-topic to I'll finish up here.
Well, update time.
With the Desoldered passthrough from the back of the screen, and the bits I picked up from Maplin, it looks like all systems go,
Followed the instructions, made a short adaptor from 15 pin VGA plug to 12 Multi AV socket.
Fitted it to the VGA out from my Laptop.
Unfortunatley my laptop doesn't do 15hz synch, even with powerstrip, so all I got was over lapping duplicate images, and scrolling. But I did get a colour picture from the VGA port.
Next test is to fire up the G450 DDR DH, with the monitor on head one, and the screen on head two, and play with Powerstrip.
If that proves unsuccessful, I have a PCI matrox Mystique 2 meg I could try.
Will report back hopefully tomorrow, with an update, picture of the adaptor, and pictures hopefully of the screen outputting.
You shouldn’t have a problem with the Matrox card as they should support the 15hz with out a problem.
It’s good to see that your making use if this and I hope it all works out ok
And yep pics are always good
Which version of powerstrip are you using?
The version I downloaded didn't include the 640x480i (arcade) option?
I have PowerStrip 3.30 Build 366
i'll add that to the how to i posted too
Hmm, I'm sure it's 366 that I'm using.
I've just downloaded and installed build 366 on my main PC (Hercules GF2MX), and it offers Arcade fine, will check which build I'v installed on the carPC tomorrow.
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
