Well, I wired it up Exactly as you said... except, in order to get picture I had to put a resistor from each color to the sync, otherwise i barely got any image... also, I cant get any color!
The image is black and white only =( What could be causing this? I'm using 75ohm resistors.. but I dont think that should matter...? =(
If i wired everything right, then Interacts 5.6" screen doesnt work.
You can’t put a resistor on all of them as you’re mixing all the signals together, that’s why it’s black and white.
You only have a resistor on the green to the sync.
Have you tried upping your brightness?
Try puting those resistors through to a ground line from each colour , instead of a synch line.
I'm sure that I saw somewhere that you need to do that to brighten the image.
You would still get the same outcome as you are still mixing the signals so it would be B&W again
but as your mixing it to ground it would make the signal even weaker.
I thought one of the original posted web sources of the Playstation to VGA hack showed exactley that though, get get rid of some of the washed out colour?
Not yours, but one from one of the console hack sources?
PSONE VGA....
Hello Everyone, I've been going through all the posts that relate to the PSONE VGA conversion and am still a bit confused and just want to clear some things up before I empty my wallet. I will list my questions in a simple list. (FYI: I will need to do NTSC)
1. M Pro's modification is done with an NTSC LCD correct?
2. Has anyone modded the official Sony LCD and if yes, was it using M Pro's modification? (His seems simple enough that I can do it
3. I have read reviews online that the Interact 5 inch version is decent. Does anyone know if this LCD can be used with MPro's mod? If not, does anyone know how to do it or know a way to do it?
4. The Redant LCD is the same as MPro's Thrustmaster Screenmate correct?
Well now that I am done being annoying, I would really appreciate it if someone could answer my questions. Thanks!
~Newb...
Hey!
I figured out that you can use ntsc singal, by connecting the video cable to the Sync Pin, and grounding the sheilding to the ground pin. Works like a charm for me
Re: Hey!
Congrats! Fusion-one! Now that you got yours working, I have some questions.
Are you using the interact 5.6 inch mobile monitor for the PSONE (Which is also NTSC)? If you are, would you be kind enough to make some sort of diagram or something that shows me how I can do the VGA mod? I am guessing that you used MPro's method, but had to do things a bit differently because the LCD was a different brand, but I dont understand what the shield pin, and video pin are. (From MPro's diagram, I only see "R, G, B, Hsync, Vsync, and ground." Sorry if I'm being a bit dense, but I am not very incline when it comes to circuits and stuff. Thanks.
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
