Results 1 to 4 of 4
Thread: Space restrictions..DVI out...to vga in...HELP!
    Oct 2008
    All I need is an item to go from DVI to VGA...taking up as little space as possible. as of right now the adapter I have is too long and the case cannot sit flush in my OEM radio location.
    I purchased this from amazon...but I think I got a DVI-I cable instead of the DVI D as there's a small pin(looks like a dash) that should have 4 surrounding slots to accept my dvi-vga adapter. Well it doesn't...
    I guess my biggest question is...can I go from HDMI to vga? My intel board also outputs hdmi and well, that would make life really easy as the cable will be far smaller.
    Sorry for the ramble, I just really need to find something quick
    May 2008
    Would something like one of these right angle adapters help?
    Oct 2008
    That was my second option, but I figured amazon would ship faster...too bad they shipped the wrong item.
    Anywhooo, I managed to move some OEM wires in my radio location and the computer JUST fits with a bit of persuasion. This is with a simple dvi/vga connector. Great find sicarius, and thanks for the help...
    ptk
    ptk is offline
    Singapore
    archy88
    i am facing the same problem. My video out uses a DVI-VGA dongle to output to VGA signal, and the combine length of the dongle, the VGA plug is simply too long. Just be careful how you persuade the fit as it might put undue stress on the motherboard.
    by the way, you should be looking for either a DVI-I or a DVI-A cable.
    You can't go from HDMI as there is no pin to carry analogue signal.
    I am exploring alternative, ie replacing the VGA plug with a DVI-A one instead. I am trying to locate a replacement cable for the lilliput 629 monitor. Not really keen to cut the original cable.
    CarPC Ver 4 completed. Aopen i45GMT-HD, C2D mobile 2GHz. Photofast 64GB SSD. Novatel EU-850D
  1. vga and dvi usage
    By carputer1 in forum LCD/Display
    Last Post: 11-11-2007, 07:54 AM
  2. Difference between VGA and Non VGA Screens??
    By sould in forum LCD/Display
    Last Post: 11-25-2005, 11:09 PM
  3. 8" Xenarc VGA Touch Screen LCD - $345 shipped in the USA
    By Zip-Lock in forum Classified Archive
    Last Post: 11-07-2005, 02:24 PM
  4. Lilliput doesn't go into VGA mode anymore
    By thefreeauction in forum LCD/Display
    Last Post: 09-23-2005, 09:48 PM
  5. 8" Xenarc VGA Touch Screen LCD - $325 shipped
    By digitalww in forum Classified Archive
    Last Post: 09-08-2005, 11:15 PM
