Ok...
So I installed Port95, but I still get that error message.
But here's the funny thing. I'm running an LCD Winamp plugin that I used with Win98 just fine. After Port95 was installed, it made no difference. So, I installed and ran the other Winamp LCD plugin that has settings for those 10 or so different LCD's, none of the LCD selections worked for my 40x4 parallel port LCD.
However... After I tried running the plugin from
http://www.markuszehnder.ch/projects...gin/index.html
and getting an error message that it couldn't find my LCD, I ran the original Winamp LCD plugin that worked with Win98, and it worked just fine!
At first I was really excited...until I realized that it only works, after you try running the newer Winamp LCD plugin and getting the error message.
This is an incredibly strange problem. You would think the older LCD Winamp plugin would work fine after Port95....AND IT DOES...only after you try running the newer plugin.
Any ideas? I hope my explanation wasn't too confusing.
LinkBack URL
About LinkBacks
