Results 1 to 5 of 5
Thread: Xenarc 700IDT in-dash fitment
    Newbie Rock Bottom's Avatar
    Jan 2006
    New Hampshire
    I'm looking into the possibility of a carputer for my Miata, and have a couple of questions about this in-dash monitor.
    First, I've read that although advertised as fitting a standard DIN opening in fact the unit is actually a little too large to fit without modifications. The posts I've seen regarding this are a few years old now, and I wondered if Xenarc might have addressed this problem on their newer units.
    Secondly, as can be seen in the pics my head unit protrudes about 1" from the dash. Would it be possible to mount the screen in the lower DIN slot, or will the head unit's encoder knob interfere with the back of the screen or prevent it from opening properly. I'm concerned that if I mount the screen in the upper DIN slot I will cover the air vents above it.
    - Rock
    Morex 3688
    MII 12k 512Mb
    M1-ATX
    Toshiba 60g hd
    Panasonic DVD RW
    iGuidance w Bu-353
    Lilliput 619 TS
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    I have a 700IDT:
    http://www.interforcesystems.com/pro...e/P6180006.JPG
    http://www.interforcesystems.com/pro...e/P6180008.JPG
    As you can see it fits in a single din opening perfectly fine. My screen also sticks out a bit, and while the screen does touch it, it does not prevent it from opening. The screen itself sticks out about an inch when closed and that is the hinge point.
    Quote Originally Posted by mitchjs
    stop with the REINSTALLS, what do you think we got some lame-o installer!!!
    RevFE - Super fast, modular frontend. Most powerful skinning engine in existence. Strong enough for an i7 made for a fitpc.
    Just a shame I can't justify a carpc to use it on anymore.
    Jan 2006
    New Hampshire
    Thanks, Malcom - that's just the confirmation that I was looking for.
    - Rock
    Morex 3688
    MII 12k 512Mb
    M1-ATX
    Toshiba 60g hd
    Panasonic DVD RW
    iGuidance w Bu-353
    Lilliput 619 TS
    Jun 2004
    Westminster, MD
    Something of note, if you have a support bar in the back of your DIN opening, you may have to use the barrel plug power connector as opposed to the 4 pin power connector just so the unit seats all the way in the slot.
    Jan 2006
    New Hampshire
    Thanks for the heads-up, Malcom. As you might imagine, the Miata is going to be a pretty tight fit all the way around. As it is, I just barely was able to get the aftermarket HU all the way in. Thanks again,
    - Rock
    Morex 3688
    MII 12k 512Mb
    M1-ATX
    Toshiba 60g hd
    Panasonic DVD RW
    iGuidance w Bu-353
    Lilliput 619 TS
  1. Replies: 0
    Last Post: 02-05-2008, 12:57 PM
  2. taking apart a xenarc 700IDT
    By evankuhl in forum LCD/Display
    Last Post: 08-30-2007, 11:45 AM
  3. Requesting Pic of Internal Xenarc 700IDT
    By Darek85 in forum LCD/Display
    Last Post: 08-10-2006, 08:49 PM
  4. Trade Xenarc TSV for Xenarc Xenarc 700IDT
    By msreyes in forum Classified Archive
    Last Post: 06-20-2006, 01:13 AM
  5. Xenarc Swivel Screen Mounted to Dash
    By pastypyro in forum Fabrication
    Last Post: 04-23-2005, 06:56 PM
