Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Is there a 6.5 inch screen?
    Newbie zvjer's Avatar
    Aug 2005
    I own an Opel Corsa OPC, and like all the current Opel's out there - the car has an plastic adaptor for OEM color screen with the hole size of 144mm x 79mm (that's milimeters). The OEM factory screen's visible size is a bit more than the plastic cover: 146mm x 82mm. This is exactly 6.5 inch widescreen, and that's the size of a screen I want to buy.
    The problem is, that everybody is selling 7" separately, but 6.5 inch only embedded in some 2din radios which I don't need.
    So what I need is (arround) 146mm x 82mm 6.5 inch screen with following standard functions:
    - VGA input
    - 800x480 physical resolution (or more)
    - USB touchpanel integrated with drivers for win-xp and/or linux
    I have already prepared a laptop computer for my in-car-pc project, but the screen is missing. The software will probably be centrafuse, but that will be decided in the end.
    Does anyone here know where can I get this size of the screen? I hope it exists!
    Thank you all!
    Opel Club Croatia
    Opel Corsa OPC
    Aug 2005
    Help?
    Opel Club Croatia
    Opel Corsa OPC
    Jan 2008
    for anyone else, a pic of your dash:
    so, you want to replace the factory lcd, with a vga version to be used with a computer right?
    you will need to look into industrial lcd monitors, mostly the ones with mounting tabs and just look through the dimensions to find the monitor that would fit your application best. here is a quick search that i did:
    http://www.google.com/search?sourcei...with+vga+input
    Aug 2005
    Only found this today: http://whlx.en.alibaba.com/product/2...or_Car_PC.html
    But it has no physical size or price. Looks suspicious
    EDIT: Maybe it's ok to be disasembled, but still no price tag.
    http://www.hiinfoglobal.com/carpc/ent650.html
    Opel Club Croatia
    Opel Corsa OPC
    Jun 2004
    I am looking for the same thing.
    I hope there is something like this. I really dont want to have to buy one of those 2din units just to take it apart and have to pay for a lot of crap that I don't need.
    If you find anything, please post. I will post if I find anything
    Aug 2005
    Which car are you working on?
    I have submitted my "what I want to buy" request to ipMart shop. Maybe they will find something.
    Opel Club Croatia
    Opel Corsa OPC
    Jun 2004
    '08 hyundai accent.
    I want something that will fit into the stock radio space. it is 19cm X 10cm.
    Jun 2004
    What about the screen from an eeePC?
    It is 15.3cm x 9.2cm with the diagonal 17.8cm (6" x 3.6" with 7" diagonal).
    We would just need to get a controller that could drive the screen. Either that, or just use the eeePC itself as the computer.
    Aug 2005
    Isn't that classic 2din space? Are you planing to fit in 2din monitor only or complete 2din computer? I want to leave my radio as it is. Only move the monitor to the roof, and in his position PC monitor should fit.
    Yeah, EEEpc is great but it's too big. See my sizes in the first post! If I would use EEE screen than I would not see it in total, so I would need to use smaller screen resolution if that would work at all.
    Opel Club Croatia
    Opel Corsa OPC
    Jun 2004
    yea, i guess it is 2din. I thought it was a bit narrower.
    Yes, I intend to put the computer into the space behind the screen which would be mounted in the front of the "radio hole"
  1. cheapest 7 inch screen
    By boysettingfires in forum LCD/Display
    Last Post: 05-09-2009, 07:32 AM
  2. 2007 Mazda 3 Dash Screen looks OEM
    By Splash-X in forum Show off your project
    Last Post: 05-04-2009, 06:29 PM
  3. Digital FX 2.0 Transparent Released
    By JohnWPB in forum RR Skins No Longer Supported
    Last Post: 03-07-2008, 01:23 PM
  4. 14 inch laptop screen
    By john1701 in forum Classified Archive
    Last Post: 07-10-2005, 01:25 PM
  5. 10.4 inch screen
    By whocarez in forum LCD/Display
    Last Post: 07-16-2003, 05:36 PM
