Results 1 to 10 of 14
Thread: Lilliput disaster. DIY Cable Extension thats not working. *FIXED!*
    Dec 2008
    needed to make this cable longer. numerous posts here and emails to lilliput and i have never found a longer version... so i must do it myself.
    i thought i would take about an hour. it did work, the first time when i had just the vga wires hooked up. as soon as i get the rest done (the usb and rca's) i find out i lost all blue color, and have never got it back since (after 3.5 hours of trying now)
    its just red and green. i have checked over my solders at least 18 times each. extreeeeemly frustrating. especially since i dont have another cable and i must make this work.
    yes, i have been hitting 'reset' and 'autoconfig' each time i try the monitor.. no bent pins anywhere...
    Vendor - Qube colin's Avatar
    Dec 2006
    Did you use a meter to check continuity?
    Dec 2008
    well i dont know what pins are what pins on each end... theyre not identical connectors on both ends so i cant test at the actual pins. and these wires are so small, to get the tape off them at all you almost always break the wire in half...
    so tomorrow i will probably take all the tape off every joint and test just after each solder point. sucks, becuase it was working before i did the other half of the wires... and it almost seems like the screen is broken. its gotta be one of my solders though... that, and any moderate tug and you can snap any one of those wires.
    Newbie dandydanny's Avatar
    Jul 2009
    Los Angeles, CA
    Quote Originally Posted by trader007 View Post
    It might be worth the effort to redo the solder job if it's indeed that fragile. Use heatshrink tubing for a more robust and easier insulation than electrical tape.
    Strip insulation, slip on heat shrink tubing, twist wire together, solder, slide heat shrink over solder joint, heat with hot air.
    Dec 2008
    its hard for me to solder wire this small without having the tubing shrink on me just from the heat traveling down the wire (i guess ill just strip back the cat5 about 4 more inches) and its only fragile because the wire is so tiny... i swear its about as thin as hair. i dont have glue-lined tubing either, so it really doesnt hold any better then the tape i use (its good tape!). i wish i had a nice set of glue-set heatshrink. either way though, this is a major PITA and i wish lilliput would just sell extension cables...
    Constant Bitrate sergatiuk's Avatar
    Mar 2006
    when dealing with wires which are that small i always use a hot glue gun to make sure the wires cant break off or disconnect after soldering them ... in car enviorment, sealing the wires with silicone or any other "rubber" glue would be the best way to make sure they stay there.
    and regarding your problem i would just redo the whole wiring and seal it well just to make sure...
    Variable Bitrate Deric's Avatar
    Sep 2006
    I thought mouser or digikey sells the male and female connections of the round connection? I'm also unsure if this would work or not but I saw the following on ebay. The posting says if you need the female version to contact them.
    http://cgi.ebay.com/Lilliput-2-in-1-...item563155c6db
    2006 Mustang with indash CarPC
    Jan 2008
    i know it is kind of late but, i just used a cheap vga extender and a usb extender-- works fine, and no soldering(i left that for the rest of the project).
    if the wires are that brittle, you are nicking them when stripping off the insulation-- you might need to change your technique to strip the wires-- any nick, and they will break very easily, but with no nicks, a single wire should hold with no problems.
    becasue it is a cable with no electronics in it, you can check continuity on all the wires--just keep testing each pin till the meter shows that the wire is good (start with pin 1 on one end, and just keep checking the pins on the other end)-- i know, it will take forever--do yourself a favor, and right down each pair that work-- it will keep you from having to go over it again if you forget(my voice of experience)...
    Dec 2008
    the pins dont align though because the 14pin connector breaks out into a 9pin plus some a/v feeds. you really cant test at the pins unless i knew what pin goes where.
    also, a vga and usb extensions i already have. i dont want the connectors right next to my open monitor. i need a cable extended as im trying... i strip the wires with my fingernail too, ive been an electrician for nearly a decade by trade- i dont knick my wires. time to get highly inebriated and try it again. im sure the 'getting wasted' part isnt helping, but my god who would want to solder 30+ connections with wire the size of a fallopian tube?
    Jan 2008
    i have had to do this before, and am not completely happy doing it, but it is the easier than resoldering everything-- you need to hold one of the leads on one of the pins on one end of the cable, and with the other lead, just keep trying different pins on the other side of the cable until you get continuity (its not easy, its not fun, and it is not fast, but much easier than desoldering, and resoldering every single connection).
    if the wire is that brittle, it is possible that it could have broken inside the sheath, so in that case, i would look at using a thicker gauge wire.
    but, if you are as frustrated as it seems(from the tone of the post?)-- forget about it for now, grab a couple beers, throw some burgers on the grill, and look into it more tommorrow...
  1. Replies: 9
    Last Post: 12-21-2006, 10:18 PM
  2. Wanted: Ultimate VGA extension cable.
    By Jzor in forum LCD/Display
    Last Post: 02-24-2006, 03:38 PM
  3. Replies: 6
    Last Post: 12-21-2004, 03:47 PM
  4. Lilliput and ribbon cable problems
    By Udonboy in forum LCD/Display
    Last Post: 11-08-2004, 08:24 PM
  5. LCD extension cable ThinkPad 560
    By hakan in forum LCD/Display
    Last Post: 03-22-2002, 08:36 AM
