Sorry for this lammer Post![]()
damn ATI radeon / LCD!
I'll try a 75 ohm RCA cable...
I just hooked up my digitalww screen to the EPIA M9000...
I show the BIOS post on the digital screen booting....
Until windows then I get no signal on the LCD...
On the driver I get the TVout grayed![]()
Impedance problem?
Will try to put the latest bios/Driver on my EPIA...
Anyway the LCD work fine with the mini camera!
Reversed image feathure is great! Thanks Armen
EDIT:
After some research on this board I think v.... where to get it? How to to it...
Solution: (Thanks netsuo)
I upraged the EPIA M9000 with the latest BIOS (TV+CRT in the same time)
I pluged a regular TV on the TVout RCA.
The option is then enabled and this time I get a propetries BOX!
So I putted PAL/Composite Output
And then I get a picture on my TV & my CRT...
Iremoved my RCA from my Regualr TV => plugged it back to the Digitalww screen and It work...
Of course I can shutdown the PC reboot.. the LCD work now all the time...cool!
Epia M9000, lili 7" vga&touch & 2xTM-7002S compo, camera with reversed image, 2.5" 60 GB, 256Mb DDR, Opus 90W, GPS usb... AND MEDIACRUISER of course!
Do you have a monitor hooked to it at the same time?
I have an EPIA M series, and you cannot do dual display. If you want the TV Out to show you have to disconnect VGA and boot.
Still not working....
I also tried ewith only the tvout and no vga connected => Same result...
When I go to windows nothing anymore on the LCD...
I tried the 75 ohm trick...the tvout is enabled but nothing happen when I am in windows...
Anyway another french member as got a EPIA M + Digitalww screen working! I'll check with him
Check the motherboard jumper for S video vs Composite video. I had to move my jumper to display video from the composite port.
There is also a jumper to set the rca out between video and digital audio out.Originally posted by richone
mike
91 cadillac sedan deville, winXP, FV25 with Celeron 800, Redant 7" widescreen in dash, Opus DC-DC, Irman, Digital Cable remote(lots of buttons), 120 gig 7200rpm 8meg cache WD hard drive, VI power mobile HD rack, mediaengine
That's the same one. It toggles the RCA port between composite and digital audio not s-video and composite...my bad.Originally posted by Michael Szilagyi
mike
ahh this problem.
If you want it on the monitor, hook up the monitor only and reset.
If you want rca-out, then rca plug only (not vga) and then reset.
Sucks doesnt it.
Mine needs to be updated.
Fixed....
I am glad you got everything working.Originally posted by PTCruiser
Fixed....
Armen
