Results 1 to 10 of 10
Thread: good deal on a 10 inch LCD
    Mar 2003
    Beijing, China
    http://www.softwareandstuff.com/h_mon_unisys105lcd.html
    Unisys brand, requires a special PCI card, no external power needed, $99
    FLAC bosstone74's Avatar
    May 2002
    Japan, Oregon
    those are poop! very low nit! (not bright)
    BossTone74
    Jun 2002
    UK
    The display they come with are crap , but I have had the 16 bit ISA version running a number of diffrent lcd's. You have to modify the bios (eprom programmer and eraser needed) and the card.
    Dave
    Maximum Bitrate churnopol's Avatar
    Apr 2003
    Delaware!!!
    It's not bad if you dont plan to play dvd's or divx
    And i didn't have to cange the bios on mine. And it has the best viewing angle for an STN lcd
    Jan 2003
    Ruston, LA
    Originally posted by churnopol And i didn't have to cange the bios on mine.
    You only have to do that to use other lcds with the card
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Dec 2002
    Illinois
    Is it possible to add a brighter backlight too it or worth it
    ddt
    ddt is offline
    FLAC ddt's Avatar
    Aug 2002
    it's been discussed at length.
    Simply put if it had a low contrast ratio, brighter backlights will just wash out all the color. You end up with a bright LCD you can't see anything on. The other option? Leave it alone and have a dark LCD you can see nothing on.
    Apr 2003
    Delaware!!!
    it has adjustable brightness controllers. I'll say it again, this is the best STN lcd monitor (but it's nothing like TFT). I use it for my carputer. The base and neck are also easy to remove. I've never had a brightness problem. But i keep it next to my arm rest. The only regret is the screen is too big. And you cannot use any other video card, it doesn't use VGA cables, it uses MDR-32. Nor does it use a VGA signal, it uses OpenLDI. Read my posts on the links below. I'm not getting into that again.
    Check out all the research i did, and my review on this monitor
    http://www.thisstrife.com/uberforum/...081&ForumUID=8
    http://www.thisstrife.com/uberforum/...030&ForumUID=8
    The reason its the best STN monitor because it uses OpenLDI instead of VGA. But the 4 meg pci card limits it abilities. There's 2 other cards out there that support OpenLDI, there well over $600
    If you really have doubts goto
    www.mp3playerstore.com
    They gaurantee the lowest prices on lcds. Also gives specials to Paypal customers
    Dec 2002
    Illinois
    guess ill just hafta save up and buy a plasma screen
    May 2003
    All over western / soutwest USA
    Anyone else trying to use these in a car?
    I have mine on a Shuttle SV24 mini PC system with WIndows 2000 Pro. Running CoPilot 2003 GPS...
