Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Old Xenarc 700TSV won't remember brightness settings
  1. #11
    May 2006
    Calgary, Alberta
    bizzle
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
  2. #12
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    Quote Originally Posted by 2k1Toaster View Post
    If the screen has power, the screen has memory. If the screen has no power, the screen has no memory.
    However, if your screen is dying and has totalled out its NV memory writing allocation, then it will lose it no matter what since it writes, the memory is fried so nothing happens, and hence goes to default. All devices have a maximum number of times you can write to them.
    I have a 700 TSV, bought in 2007. So what you're saying is not true for that one.
    It is powered by the DSATX PSU (so it has no power at all when the computer is off). I've set my monitor to rotate 180 degrees only once (!), since I installed it overhead. Never had to do it again. EVER. Same thing with 16:9/4:3 settings, backlight 99, etc. No matter if it was off two weeks, it always remembered those
    Brightness and contrast however, by designed, are f*ed.
    This has nothing to do with your hardware. There must be some factory hidden setting to save brightness and contrast as the other settings....
  3. #13
    Mod - all of it.
    Jul 2007
    Buena Park, So Cali
    Okay, I know that this may be a simple answer, and I could be completely off base and wrong. I seem to remember reading somewhere that you need to set the settings, power cycle the screen with the remote or the power button on the unit. When you turn it back on it will have retained the settings. If you let the screen turn off by the ignition it will not have remembered the settings.
    I had trouble with the auto adjust needing to be redone each time I turned on the car and this seemed to take care of it.
    Like I said I could be completely off base so don't flame please.
    CAR: 2007 G35 Sport Coupe 5AT
    HARDWARE: Dell D630 w/ dock, internal 80G HD, internal 320G HD, Verizon Wireless Card, iBlue GM-2 GPS w/iGuidance, OBDPros w/DashCommand, Visteon HD Radio w/ Home Made Cable, Current Version of RR w/ DFX Skin. My Install.
  4. #14
    Dec 2007
    Danville, CA
    You're not completely off base, there's another thread where someone said that worked for him. You're supposed to power cycle with the remote while the overlay menu is still showing (and doing all the setting with the remote too). It didn't work for me, but it's worth a try, I think.
  5. #15
    May 2006
    Calgary, Alberta
    Quote Originally Posted by RipplingHurst View Post
    Just tried this:
    remote off, remote on = saved settings
    car off, car on = no saved settings
    remote off, car off, car on, remote on = saved settings
    It's like whenever I use the remote they're saved but the second the car is turned off with the screen on, it loses them.
    Found this in another thread with no resolution:
    ok, never used a Xenarc before but ... most monitors store information regarding their settings on a per resolution/refresh rate basis. so when you change either of them, it goes to the factory settings for that resolution unless you have changed it before. you can try it on the machine you are on now probably, just switch to some resolution that youve never used before and chances are it will be all messed up aligment-wise. hope that helps ... try and see what happens when you set your resolution back to what it was before.
    I do remember forcing the resolution in the Road Runner configuration so maybe if I set the Windows resolution and leave it, it won't refresh and lose the settings. It seems like anytime the refresh rate or resolution change, the settings are lost and powering down the screen with the remote prior to turning the car off/on stops the resolution from changing a few times on bootup. I'll try that tonight.
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
  6. #16
    Dec 2007
    Danville, CA
    Interesting findings...I wonder if using the screen buttons instead of the remote could also be used to save settings. I mean, if it saved whenever it was powered on/off by the screen buttons, maybe a relay could be used to start it every time the computer starts (I wouldn't know how to do this with IR signals).
    As for the resolutions issues, it makes sense, but every time my computer boots, resumes, it goes through a bunch of crazy resoltions, with the screen flickering at each change...I'm using 800x600 in windows, not forcing anything, still I see 720x400, 800-480, and others, until 800x600.
  7. #17
    May 2006
    Calgary, Alberta
    Ya, my computer does some crazy refresh rates. It'll do 61 hertz, then 59, and then settle on 60 every time it boots.
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
  8. #18
    May 2006
    Calgary, Alberta
    Well that was an easy solution. I changed the Windows resolution from 800x600 back to the 1024x768 I was always using before. Works fine now!
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
  1. FS: Xenarc 700TSV Touch Screen Monitor
    By VYR8 in forum Classifieds
    Last Post: 01-17-2009, 11:21 PM
  2. Replies: 15
    Last Post: 10-18-2005, 05:42 AM
  3. Xenarc 700TSV Buttons.....
    By Cheekz185 in forum LCD/Display
    Last Post: 07-11-2005, 11:20 AM
  4. Xenarc wont remember settings
    By Ascension in forum LCD/Display
    Last Post: 06-29-2005, 10:06 AM
  5. Xenarc 700TSV Resolution
    By blackflux in forum LCD/Display
    Last Post: 05-18-2005, 01:51 PM
