Datalux - VGA Cable Power is the Pin + ?
Hey Guys,
I have searched and couldn't find the answer to this seemingly simple questions...
I have a Datalux LMV10 without a power cable. I am going to make my own and I need to know if the cable should be inside positive (outside negative). Is the pin on the Datalux cable positive? I looked on their website and can't seem to find that info...I found it for the S12, which says "Mates with Switchcraft model 760 jack or equivalent; barrel 2.5mm ID 5.5mm OD outside neg."
Any help would be appreciated!
- Jeff
hmm the power for my screen is comming from the vga to tft controller.
Does your screen turn on at all? You are kinda unclear, I would gladly help you out seing I have a datalux setup.
Hello Osirisdon,
Thanks for the response. The Datalux is intact - still in its case. The VGA cable from the case terminates in standard 15 Pin fashion, however, there's a power connector built into the top of it.
Check this page out to see a small B&W pic of what I'm talking about:
http://www.datalux.com/generic/manua...structions.pdf
Thanks!
- Jeff
Hey Matty,
Yes, that was for the 12 in. version - I wanted to make sure the 10.4 inch was the same before I go hooking it up that way and blow up my precious controller inside.
I know outside neg. = outside negative
- Jeff
its 12vDC, I have the same exact lcd and its 12vDC oh wait I already said that.
If you have any other questions contact me via AIM more than willing to help you out.
Originally posted by jzgt
Hey Matty,
- Jeff
Im pretty sure that the connection standard is outside negative. Wouldnt know why they would change it for this LCD
I have the 10.4 inch and its outside neg mkay?
Thanks for checking. I figured they wouldn't change it but I'd rather not open it right now and I didn't want to blow it up when I was sure someone else out there had one and could check for me.
Thanks for the help!!
- Jeff
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
