Results 1 to 10 of 12
Thread: lilliput loses signal after time
    Mar 2009
    So I typically never notice this, but on trips of over an hour (I don't notice because my trips are less than an hour usually) the lilliput (629) will lose the pc signal. I can turn it on and off (with remote) and still doesn't have signal. It happened last night and I turned the car off and left it over night and back back this morning and everything worked fine, after changing nothing.
    Could it be a heat issue? I don't see how it could be... because it doesn't get that hot...
    Ideas?
    Apr 2009
    I just had the same thing happen to me today, screen turned off and then when i shut off car it came back up to show shut down procedure was commencing.
    Oct 2009
    bump for answer... mine is doing the same exact thing.
    Apr 2009
    bump
    Newbie s00pa's Avatar
    Nov 2009
    Lower Hutt, New Zealand
    If the screen goes blank or goes into standby, it could be that windows power management is set to turn off the monitor after some time of inactivity, which makes the graphics card stop its output. If this was the problem though, simply moving the mouse would bring it back, so this probably isn't the problem but I would check power management settings anyway, maybe the profile was changed etc.
    Acer Aspire One carputer
    1983 Mitsubishi Sigma SE
    Progress: [||||||--------------]
    Temporary netbook setup complete
    Planning a real carputer...
    Apr 2009
    Quote Originally Posted by s00pa View Post
    thank but i would hope that if someone took the trouble to post about it that they would have the common sense to see if the power settings were turning off the monitor lol.
    anyone else?
    Aze
    Aze is offline
    Dec 2005
    Roskilde, Denmark
    The older types of Lilliput 619/629 had some problems in the mainboard, that makes the picture disappear after using for a while. For the old types it WAS a heat problem, even though it doesn't seemed very warm.
    What solved the problem was changing the mainboard. I'm pretty sure this could be your problem.
    How old are the screens?
    Constant Bitrate sergatiuk's Avatar
    Mar 2006
    Quote Originally Posted by Aze View Post
    i have also heard of this problem a while ago. try adding a fan in the back cover of the monitor (u have to remove the speaker for that and make a hole for the fan).
    but this should solve your problem.
    dont forget to double check your power settings in the OS that you are using... and just in case make sure you have no screensaver set...
    either way cooling the older lillies never hurts... actually it should extend it's life
    2007 Toyota Tundra Double Cab SR5
    >"Say what you mean and mean what you say"<
    Apr 2009
    screen was bought about 4 months ago from mp3car. its the new style 7" lilli so i assume it shouldnt have an issue
    Mar 2006
    no it shouldnt, triple check your system settings.
    if everything is good there try to input a different video device, like a camera or a dvd player or just about anything else and see if it still looses signal after an hour. if it does you might need to use you warranty. if it works fine then it sounds like an issue with the PC itself.
  1. New OBDII scantool - Beta testers?
    By tmort in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-29-2010, 01:06 PM
  2. Replies: 7
    Last Post: 12-06-2006, 10:24 PM
  3. Lilliput won't respond to VGA Signal
    By mushupork5 in forum LCD/Display
    Last Post: 02-02-2006, 08:58 PM
  4. Lilliput LEDs stay on all the time modification
    By NRGZ28 in forum General Hardware Discussion
    Last Post: 11-21-2004, 01:30 AM
