Results 1 to 2 of 2
Thread: Lilliput EBY701 2008 VS 2009
    Low Bitrate atrixstars's Avatar
    Oct 2006
    hi, I noticed the only thing different is resolution. What resolution would most people run 800x600 or 1024x768? I also noticed both can be LED?
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    Im assuming you are comparing the new LED vs old CCFL Lilliputs. I looked at the datasheet for the two LCD panels they use inside. It seems the newer LED is actually not as bright as the old CCFL based on the data. Havent seen a side by side comparison of the two, so I cant comment on how valid this is.
  1. Lilliput EBY701 breakdown
    By shawnmiller in forum LCD/Display
    Last Post: 08-12-2008, 04:15 AM
