Results 1 to 7 of 7
Thread: Considerations for character lcd's?
    ddt
    ddt is offline
    FLAC ddt's Avatar
    Aug 2002
    What should I consider when purchasing a character lcd from ebay, other than availability of a datasheet, to use with the various winamp plugins? Like does it NEED to be 16 x 4 or 40 x 4 or are these plugins configureable?
    I know nothing about these plugins or character lcd's in general so spell it out for me. Thanks!
    Maximum Bitrate Raas's Avatar
    Jan 2001
    The Netherlands
    Hi,
    Iīve been playing around with the markuszehnder plugin v0.6 lately. I use it with a 40x4 and Iīm pretty impressed.. Like almost anything is configurable: Where you want to put which information. It also has an menu that is displayed and where you can select the options. It also supports multiple inputs, from keyboard to parallel and serial, and even WinLirc works. It even has an on-screen simulation so you can test it out on your monitor when you donīt even have an lcd attached to your computer.. The plugin is constantly in developement as the last version is only a bit older than a month... Oh yeah... the plugin also works with the albumlist plugin, so you can browse your albums and artist on your lcd. It also supports playlists which you can choose. You can define custom characters to be displayed... you can have multiple output-set to a display, so that it displays a lot more information about a song, or hardware things like mem usage, cpu usage, drive usage, when the player is like in pause-mode, and then have the normal screen back, when you continue playing..
    Eurrrrrhhhhmmm... did I forget something ?
    Check it out.. itīs really cool
    http://www.markuszehnder.ch/projects/lcdplugin
    Greetz,
    BTW... 600 posts... yay !!!!
    Raas - The Netherlands
    ME: VIA epia m10000, lilliput 7', opus 150w, 80gb<br>
    GF: IBM Thinkpad 380, ext. 3.5 80gb, 40x4, PB-IR
    Sep 2002
    Just North of Toronto, Ontario, Canada
    Most of the sizes are standard, 8,16,20,40 wide are supported in all software i think, with either 1,2 or 4 lines of text.
    Ive seen some 24 character wide ones, and im pretty sure they arent supported in all software.
    You can either get serial or parallel, although i think the cheap ones on ebay will all be parallel. Make sure its HD44780 compatable as that is the standard controller chip. Theres a few different chips that are they same spec, i know theres one by epson, then some other japanese companies. Im pretty sure almost all of them are HD44780 compatable, but just something to double-check.
    Project AutoBoxen: Coming along, almost ready to hook up in the car.
    Celeron 500, 192mb ram, 8gb hdd, other stuff.
    '91 Mazda 626: Its free, so ill use it.
    Jan 2001
    The Netherlands
    Well, i know for sure that if one bought a 20x4 and played with it for a little while he would regret it, that he hadnīt bought a bigger one..
    nowadays the char.lcd are not that much used here, every1 is going for tftīs but back in the days when the char.lcdīs caused a lot off talk in the forums here, anyone would say, "Go with 40x4, bigger is better"
    (if your dash has some more room where the 1 din HU would be placed, you could place the 40x4 there.. the print is just slightly bigger than the 1din dimmensions...)
    greetz,
    ddt
    ddt is offline
    FLAC ddt's Avatar
    Aug 2002
    This is more for a HTPC I'm wokring on.
    Thanks for the info guys.
    Maximum Bitrate digitalww's Avatar
    Sep 2002
    ILLINOIS
    Check out these sites, lots of good ideas:
    http://iceforums.net/lcd/?f=view&PHP...cac1a200aa156d
    and
    this one for plugins http://liquid-mp3.schijf.org/
    Armen
    Jan 2001
    The Netherlands
    Thatīs also I want to do sometime...
    yeah,
    If you would take MediaEngine, MyHTPC, MarkusZehnder Plugin and some PVR/TV/TimeShifting software... , throw it in a blender and mix it all toghether you would have a really cool app..
    Like all info that is displayed on normal stand-alone VCRīs DVDīs SATīs would be displayed on the char.lcd..
    Now that would be really cool....
    and it would be the only device needed (except for an amp and tv)
    New project guys ???
    Greetz,
