Results 1 to 5 of 5
Thread: Lilliput board smoke
    Aug 2008
    Hey all,
    Yesterday I started to see this puff of grey smoke coming from my screen, so I took it out could see saw that the plastic connector which connects the AC adapter was melted and a capacitor was smoking.
    Today I tried turning the screen on with no luck, is my screen fu**ed?
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    If you are lucky, maybe just the power connector shorted out. Can you solder on new power lines to the circuit board traces and replace the capacitor? Im guessing those could just be the power filter capacitors.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    There is a fuse (Little white rectangular thing near the pwr connector) on the controller board which may have gone.
    However, it's probably likely whatever went up in smoke shorted out and triggered the fuse to blow.
    Variable Bitrate Deric's Avatar
    Sep 2006
    That capacitor looks really bulged on the bottom. I would replace the capacitor and the power connector. Both may be available at Radio Shack if you have one near by. Check for a fuse as others have mentioned too but if that capacitor is shot you probably won't power up.
    Dec 2007
    mine did it to it was an old ccfl 629, i ordered 100 16uf caps for 10 bux and it saved my but!
    jsut change out the cap and you will be fine
  1. replacement control board Lilliput
    By landonb16 in forum LCD/Display
    Last Post: 02-18-2007, 07:53 PM
  2. WTB: lilliput 619 LCD controller board
    By anik321 in forum Classified Archive
    Last Post: 08-29-2006, 07:24 PM
  3. WTB: Button circuit board for 8" Lilliput LCD.
    By MustangCruiser in forum Classified Archive
    Last Post: 09-15-2005, 11:02 PM
  4. WTB: board for 7" lilliput
    By jaymx211 in forum Classified Archive
    Last Post: 04-12-2005, 05:14 PM
  5. WTB: Lilliput VGA Controller Board
    By Grayscale in forum Classified Archive
    Last Post: 07-23-2004, 03:35 AM
