Results 21 to 30 of 35
Thread: Ruined a ribbon cable on a Xenarc 705TSV monitor. What do I do?
  1. #21
    Low Bitrate ph7ryan's Avatar
    Dec 2008
    Atlanta
    ok...i understand that it is a zero insertion force connector...THAT IS IRRELAVENT. Does no one really understand what I am saying....He said that there are some bent pins, but they aren't touching anything so its ok...then he asks what is wrong...uuummmm hello...the pins aren't touching anything...
  2. #22
    Variable Bitrate hailrazer's Avatar
    Mar 2008
    Columbus, Georgia
    Quote Originally Posted by ph7ryan View Post
    Yes well I think he meant they aren't touching each other or the board, but I could be wrong.
    It would be quite simple to bend all the pins straight again. But I really haven't seen a zif socket that has pins that can be bent easily just from an ffc being pulled out. That's why I'm wondering if the zif was broken off the mainboard.
  3. #23
    Dec 2008
    Atlanta
    Quote Originally Posted by Maheriano View Post
    But I'm also wondering with this screen......the bent pins are on the side of the ribbon cable with the black stripe, the exposed pins on the cable are on the other side. These bent pins aren't contacting anything so would it matter at all that they're bent? Who cares right? And I have the original ribbon cable to make sure I'm actually facing this new cable the right way which is correct. For some reason it's still not working with the new cable, I thought it was the bent pins initially but if they're not contacting the cable it can't be that. I'm lost now....
    Ok...do we need to go back to basic electrical physics...do you know what a conductor is...its something that conducts electricity...On computer electronics, a voltage means 1....no voltage means 0...if everything is 0 all of the time, how is it supposed to work???...It isn't magic...the voltage has to get there somehow..and they don't just put wires there to hold the thing together...
  4. #24
    Mar 2008
    Columbus, Georgia
    Ummm magic electricity........
  5. #25
    Dec 2008
    Atlanta
    i know like really...does he think that the pins are just there to look cool...obviously if they aren't touching anything on the cable that is an issue...that is the solution...I don't see the problem...
    honda owners...
  6. #26
    Dec 2008
    Atlanta
    uuummmm...try it...if the pins are supposed to be underneath, then put them underneath...
  7. #27
    May 2006
    Calgary, Alberta
    Finally he gets it.
    Okay, here's the deal. I realized after talking to Jimmy at Xenarc that those bent pins do make contact with the underside of the ribbon cable afterall. The way I have it in the picture the cable is under the pins. I have to pull the cable back out and lay it on top of the bent pins but then there is no way for it to stay in place right? Well that's where the ZIF would come in, it's supposed to flip down and press the cable onto the pins creating contact. THIS is why it's not working, I had the cable in the wrong spot. And when I put it in the right spot I have the problems of bent pins and no ZIF.
    So hailrazer, where do I buy this brown ZIF? It is a flip down, not a slide out and it snapped in half when I picked it up off the work bench. I'm determined to get this working somehow. Or sell it on Ebay.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
  8. #28
    Mar 2008
    Columbus, Georgia
    Finally he gets it.
    I need a pic of the ffc against a mm ruler so I can tell the # of pins and pitch. Like this :
    Then I can get you a part # from digikey for you to order. It will be around $6-$7 shipped and take around a week to get it.
  9. #29
    May 2006
    Calgary, Alberta
    Quote Originally Posted by hailrazer View Post
    What's FFC? The ribbon cable?
    Right now I'm trying to use the 15 centimeter cable I got from the mp3car.com store which looks to have the same pitch as the Xenarc one. But if it doesn't work I already have an original Xenarc cable on the way which is only about 1.5 inches long. I'll get a picture of both for you.
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
  10. #30
    Mar 2008
    Columbus, Georgia
    Yes the ffc ribbon cable, take a pic of the end of it against a mm ruler just like the pic I showed
  1. Ordering replacement lilliput ribbon cable
    By FLESIK in forum LCD/Display
    Last Post: 07-03-2006, 11:58 PM
  2. Where to buy Xenarc ribbon cable
    By dmurray14 in forum General Hardware Discussion
    Last Post: 05-04-2006, 10:06 PM
  3. need replacement ribbon cable + connector
    By keyvan in forum LCD/Display
    Last Post: 04-05-2006, 02:22 AM
  4. FS: Xenarc 700-IDT & 16-ft Cable - BRAND NEW!
    By hd54321 in forum Classified Archive
    Last Post: 09-27-2005, 05:02 PM
  5. Replies: 8
    Last Post: 12-05-2003, 11:40 PM
