Page 4 of 4 FirstFirst 1234
Results 31 to 35 of 35
Thread: Ruined a ribbon cable on a Xenarc 705TSV monitor. What do I do?
  1. #31
    Low Bitrate ph7ryan's Avatar
    Dec 2008
    Atlanta
    wtf are you talking about "finally HE gets it"...your the retard that made the statement that if the pins are not touching the cable it should be ok...I understood from the beginning that there were some pins underneath...I still don't get what your original question was...It was just phrased so stupidly that only you understand the original question..I know what was going on...just not what the question was
  2. #32
    May 2006
    Calgary, Alberta
    Quote Originally Posted by ph7ryan View Post
    Relax. I appreciate your help, I'll explain it again.
    You can see where the pins come out. You can see they don't touch anything and they still wouldn't even if they were straight and not bent. My question is this.....does it matter if they're bent because they don't do anything anyway? I already have my answer, the cable is positioned wrong. It should be above the pins so the underside of the cable does in fact make contact with the pins and therefore the bends do matter.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
  3. #33
    Dec 2008
    Atlanta
    ok...and my point from the beginning was that they would not be there if they did not matter...
  4. #34
    Dec 2008
    Atlanta
    Quote Originally Posted by chkolny View Post
    lol, stop posting in this thread, you are not contributing
    speak for yourself troll...
  5. #35
    May 2006
    Calgary, Alberta
    It's his monitor I broke.
    Hellrazer, I'll get on that as soon as I find a ruler and a camera. Thanks.
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
  1. Ordering replacement lilliput ribbon cable
    By FLESIK in forum LCD/Display
    Last Post: 07-03-2006, 10:58 PM
  2. Where to buy Xenarc ribbon cable
    By dmurray14 in forum General Hardware Discussion
    Last Post: 05-04-2006, 09:06 PM
  3. need replacement ribbon cable + connector
    By keyvan in forum LCD/Display
    Last Post: 04-05-2006, 01:22 AM
  4. FS: Xenarc 700-IDT & 16-ft Cable - BRAND NEW!
    By hd54321 in forum Classified Archive
    Last Post: 09-27-2005, 04:02 PM
  5. Replies: 8
    Last Post: 12-05-2003, 10:40 PM
