Page 12 of 25 FirstFirst ... 2345678910111213141516171819202122 ... LastLast
Results 111 to 120 of 245
Thread: capacitive touchscreen with controller
  1. #111
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    Nice to see another Mazdaspeed owner hacking that motorized housing from china. I own the same thing and modified it with a transflective lilliput from the mp3car store. Are you running the stock monitor and controller? or is that a lilliput?
    Quote Originally Posted by thanh510 View Post
    Well, since no one is posting an updates with pics, I will!
    Resistive!!!
    <br>
    <br>
    <br>
    CAPACITIVE!!
    Holy-cow. Talk about a significant improvement in glare reduction. The first resistive touch photo had similar lighting as capacitive, so side by side comparison is in order.
    Gloomy day vs indoors!
    I will post more pictures when it is sunny! Gloomy day today.
  2. #112
    Constant Bitrate JayKaye's Avatar
    Jan 2004
    Sydney, Australia
    Thanks for your help Maddnezz and Truckinnines.
    Ill be ordering mine soon!
    Car PC v1 - 1999 - 2000
    DOS 6.22 - MPXF - 2x16 LCD - 6.4GB
    Car PC v2 - 2002 - 2006
    XP - 7" wide/touch - GPS - Tank batt relay - 100GB
    Car PC v3 - 2008
    XP - 7" wide/touch - GPS - 802.11g - FM/XM - OBDII - WWW
    [||||||||||||||----] 80% complete
  3. #113
    Variable Bitrate Deric's Avatar
    Sep 2006
    Has anyone found an 8" widescreen version?
  4. #114
    Mar 2010
    Quote Originally Posted by Deric View Post
    Don't know of one for sure but you can go here and input your screen's dimensions to find out.
    My friends see me putting a computer in my car and ask "Why?". I saw there was no computer in my car and asked "Why not?" - Ripoff of Robert Kennedy
  5. #115
    Mar 2005
    Pomona, CA
    Quote Originally Posted by Maddnezz View Post
    I would guess that it is. If you read the install datasheet it states that the controller needs to be grounded and if I remember correctly it recommends grounding to the screen. I mounted mine to the side of the double DIN LCD kit and just ran a ground wire from the screw hole on the board to a ground point that was relatively close, I just do that out of habit with cards like this as the screw holes tend to be common ground.
    Grounding it to the LCD panel/controller seemed to work great. The noise is more or less gone, and the calibration has improved significantly. Much improved overall. Way better than the resistive panels.
    Low Bitrate sedtc's Avatar
    Jul 2006
    tally-ho, fl
    i've searched and come up empty so far...
    this would be a great mod.
  7. #117
    Low Bitrate Gecko483's Avatar
    Feb 2008
    Anaheim, CA
    @thanh510:
    THANK YOU for the awesome pictures!!!!!!
    This was all i needed to convince me to do this mod.
    @antimatter
    I am glad to see someone else has the 7" transflective lilliput from the mp3car store. You substituted the original resistive touchscreen for the capacitive? I have had this monitor in my car for about 4 months and I am not convinced it was the best solution as far as the clarity and resistive squishyness. The pictures are like night and day, plus i am so sick of the amount of force that is needed to make the resistive touchscreen react.
    I already ordered the parts and they should be here in three days. I cant wait to do this modification.
  8. #118
    Dec 2007
    I got mine from online components last week, it fit perfectly between the stock LCD mount screw holes in my 2006-ish EBY-701 bezel.
    i will need to get longer screws, as the capacitive touchscreen is a little thicker, but the thing looks goregeous! VERY MUCH worth the $68 i spent.
  9. #119
    Jan 2004
    California
    Quote Originally Posted by Z0rr0 View Post
    Can you post pictures. Is this the 7"?
    Has anyone done this to any transflective screens.... if so is it worth it?
  10. #120
    Dec 2007
    Quote Originally Posted by antimatter View Post
    sure.. i'll take some pictures tonight.. i just got my replacement LCD ribbon cable.. so i need to test it anyway.
  1. WTB: lilliput 7" touchscreen controller
    By Sonicxtacy02 in forum Classified Archive
    Last Post: 06-22-2005, 08:29 PM
  2. Replies: 2
    Last Post: 01-12-2005, 08:57 PM
  3. FS: USB controller for a touchscreen panel
    By NoPistonPC in forum Classified Archive
    Last Post: 05-09-2004, 09:26 AM
  4. Replies: 0
    Last Post: 05-06-2004, 01:56 PM
  5. FS: USB Touchscreen Controller card
    By sniz55 in forum Classified Archive
    Last Post: 04-29-2004, 07:48 AM
