Page 14 of 25 FirstFirst ... 456789101112131415161718192021222324 ... LastLast
Results 131 to 140 of 245
Thread: capacitive touchscreen with controller
  1. #131
    Sep 2000
    LA, CA, USA
    Wow everyone is right about how much better the LCD looks through this. It's crazy how much the resistive panel was clouding and modifying the colors. Haven't put it back in the car yet but looks to be worth the $55. Not to mention the difference in responsiveness.
  2. #132
    Aug 2006
    Does anyone know how to reverse the axes on your touch screen? Turns out mine are backwards. ie, when I touch upper left, it goes lower right.
  3. #133
    Aug 2006
    Nevermind. Easy answer. The calibration utility accounts for it.
  4. #134
    May 2009
    Anybody know if your can replace the stock resistive panel on my OEM navi to a captive touchscreen?? It hooks to the stock board with 4 wires.
  5. #135
    Low Bitrate Gecko483's Avatar
    Feb 2008
    Anaheim, CA
    You would have to engineer it. If the existing resistive panel plugs into that board in the picture you would have to find a way to bypass the resistive touchscreen controller and interface with a capacitive touchscreen controller. You can not use a resistive interface to control a capacitive screen.
  6. #136
    Maximum Bitrate tft_lcd_org's Avatar
    May 2010
    Detroit, MI
    Plus, if you can figure out the interface for the controller (usb or serial?) you will need to get the drivers installed for the capacitive touch controller.
    You said this is for a factory nav? doubtful that it would work.
  7. #137
    Feb 2008
    Anaheim, CA
    The only thing I have personally seen work with factory NAV units is someone using the screen as a display for computer and even that is tricky. Upgrading a touchscreen from resistive to capacitive is not exactly an easy task either. I have not heard of anyone able to modify the touchscreen in an existing factory NAV unit. If you are successful, post your results and process so that others may follow in your footsteps.
  8. #138
    May 2009
    Factory nav screen aside isn't this what everyone here is doing upgrading resistive touchscreen to captive? Whats involved in this process for those with aftermarket screens?
  9. #139
    May 2010
    Detroit, MI
    Depends on what screen you have.
  10. #140
    Low Bitrate Belo's Avatar
    Jan 2010
    Buffalo, NY
    i know this was just came out today, but any plans to sell a capacitive touchscreen of liliputs new 5 wire?
    Some of us aren't to crazy about doing the retrofits ourselves.
    http://store.mp3car.com/ProductDetai...ctCode=MON-123
    09 Pontiac G8GT [decently modded]
    former carputer owner, given up for iphone
  1. WTB: lilliput 7" touchscreen controller
    By Sonicxtacy02 in forum Classified Archive
    Last Post: 06-22-2005, 09:29 PM
  2. Replies: 2
    Last Post: 01-12-2005, 09:57 PM
  3. FS: USB controller for a touchscreen panel
    By NoPistonPC in forum Classified Archive
    Last Post: 05-09-2004, 10:26 AM
  4. Replies: 0
    Last Post: 05-06-2004, 02:56 PM
  5. FS: USB Touchscreen Controller card
    By sniz55 in forum Classified Archive
    Last Post: 04-29-2004, 08:48 AM
