Page 17 of 25 FirstFirst ... 78910111213141516171819202122232425 LastLast
Results 161 to 170 of 245
Thread: capacitive touchscreen with controller
  1. #161
    Maximum Bitrate tempgp's Avatar
    Jun 2007
    New York
    Now wait a minute, liquid rubber? You cover the whole lcd panel with it and then lay the capacitive panel on top of it and it is transparent? wow. Very cool. Where do I get a gallon of this?
    Covering LCD w/ anything event transperan material is not good idea it will not be perfect. I used liquid rubber to as a gllue, i pured it on the metal part of LCD i let it dry for 8min to get hard-er then i placed touch pannel over it pressin and adjusting for proper angle but so rubber is not squzed oout. If you use soft rubber like 20-40 point then tiy can let it dry completly and put screen on top.. in that case when some one oresses in scree too hard it will go back a bit giving them the feal of toch so they wiil firgure out that they pushjed enough and can let screen go alredy. [I use "smoothon" fom my rubber / plactic chemicals]
    As to contract, the spacer film will not mae it better but only worthers, you need better screen then ot check your cables / resolution .
    Wet rubber, let me look up where you can get it
    http://www.amazon.com/3M-00051138979.../dp/B002QMX6CE
    Here thats 30mil tape (it like 2 credit card thick, well a bit less) if it it is less then 3 yesr old then it should be reasonably sticky
    Acura / Honda A/V CarPC Adapter GA-NET+
    Centrafuse Garmin Mobile PC Skin - GMPC Rebellium Skin
    3D Tuning and Car Visualizer - Preview your car in 3D, change paint job and rims
  2. #162
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    Ah, so you do not cover the visible portion of the LCD at all (like those optical bonds do).
    Interesting points, but I think the 30mil tape is too thick for me, that's a lot of air between the panel and the glass (more reflection). I was thinking I was just lay one on top of the other and just screw something plastic over the sides, but I like the wet rubber idea better now.
    Thanks.
  3. #163
    Jun 2007
    New York
    you need to put some sort of spacer in between so vibration does not scrtach both surfaces.
    Covering whole glass w/ anything is not a good idea, tranperant silicone tapes are good if you have perfect surface (i doubte you do in the car as tiucg screen can get pressed in and then "pull" out a bit so thape will show visible signs of air bubbles.
    Similarly if you get liquid glass (forgor what plastic is used for that, i have 3 diferent cans in garge) so when it drys oput it may bubble, also its material dencity may dissirt image slightly but since it is monitor you probabl want crystal clear image, and finally plastic bonding to not glossy surface will create small cavitis which are not really visible but they will work and lesne sand disort image,,,,...... If you have spare monitor you can try to use clear silicon liquid, that might work ( but i never tried and i dont know) the reason why it may work is becauuse it is soft, I would personally never fill monitor surface w/ anything ...
  4. #164
    Dec 2007
    Danville, CA
    Got it.
  5. #165
    Jun 2007
    New York
    good
  6. #166
    Dec 2007
    Danville, CA
    still want the liquid rubber though...send me some via PM...
  7. #167
    Jun 2007
    New York
    move vloser to NY and I will give you reagent and hardener ins small bottle
    I have too much anyway but I cant ship flameble chemicals
  8. #168
    Dec 2007
    Danville, CA
    Heh, thanks. I'll try some home made stuff here, something thinner than the one you linked...Got to do some research on my 12.1 capacitive panel now.
  9. #169
    Jun 2007
    New York
    there are thinner tapes, i just dont remember sizes out of the top of my head
    there should be 11mil tape but its hard to find one as damn duck tape is 11 mil too so you get lots of duck tape coming in the serch
  10. #170
    Jun 2007
    New York
    oh 11mil is a size of NYC Metro Card, dont know what to compere to something down south
    perhabse size of laminated business card?
  1. WTB: lilliput 7" touchscreen controller
    By Sonicxtacy02 in forum Classified Archive
    Last Post: 06-22-2005, 09:29 PM
  2. Replies: 2
    Last Post: 01-12-2005, 09:57 PM
  3. FS: USB controller for a touchscreen panel
    By NoPistonPC in forum Classified Archive
    Last Post: 05-09-2004, 10:26 AM
  4. Replies: 0
    Last Post: 05-06-2004, 02:56 PM
  5. FS: USB Touchscreen Controller card
    By sniz55 in forum Classified Archive
    Last Post: 04-29-2004, 08:48 AM
