Results 1 to 2 of 2
Thread: USB to VGA, DVI or HDMI
    Variable Bitrate UnusuallyGenius's Avatar
    Mar 2009
    Grand Rapids, Mi
    USB to VGA, DVI, HDMI Adapters, how good are they really?
    Do they honestly work for playing DVD's on?
    How many is too many? When do you notice performance issues?
    Can they really drive a HD screen at say 1080i? (not that I will have 1080i in my truck)
    - Check out OpenMobile
    - OSDash
    Constant Bitrate sergatiuk's Avatar
    Mar 2006
    i personally never used one but you should take into consideration that USB devices are processed by the CPU, CPUs are not designed to process/render video. from my experience with linux, a dual core pentium M CPU is capable of playing 720P, 1080i and probably 1080P if my LCD would support it.
    when video is processed by the CPU you should expect the CPU to reach very high temperatures as it is being used at 90%-100% capacity. this is how i burnt the fan on my acer lappy.
    you also have to consider the fact that while the CPU is processing video the OS would not be very responsive.
    the new ION boards might handle this better because this chipset is designed for that purpose.
    from my experience a dual core is capable of pushing 1 output, i believe a quad core will push 2, but i doubt it will handle more then that.
    2007 Toyota Tundra Double Cab SR5
    >"Say what you mean and mean what you say"<
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  2. Powered USB Hub Anyone?
    By Lukeyson in forum General Hardware Discussion
    Last Post: 07-09-2009, 05:54 PM
  3. Lilliput GL701 VGA usb cable switch to DVI?
    By AJWatU in forum LCD/Display
    Last Post: 07-15-2007, 07:07 PM
  4. Found Cheap Cables: VGA 10ft $6, USB Extension 10ft $2 and More!
    By WarDriver in forum General Hardware Discussion
    Last Post: 07-13-2006, 12:04 AM
  5. Lilliput USB and VGA connections
    By FunkDaMonkMan in forum LCD/Display
    Last Post: 01-01-2004, 09:32 PM
