Results 1 to 6 of 6
Thread: re: Best way to bond plastic?
    Low Bitrate atrixstars's Avatar
    Oct 2006
    hi, I need to best way to glue or stick platic together? I cannot used super/gorilla glue I need a paste like liquid to cover a big area 1x2 inch or larger. No sanding needed just need it to stick.
    Constant Bitrate sergatiuk's Avatar
    Mar 2006
    Quote Originally Posted by atrixstars View Post
    silicone
    2007 Toyota Tundra Double Cab SR5
    >"Say what you mean and mean what you say"<
    Variable Bitrate hailrazer's Avatar
    Mar 2008
    Columbus, Georgia
    Abs cement will bond permanently most plastics together.
    Jun 2009
    Permatex makes a plastic cement that is like a 2 part epoxy, but is creamy coloured. It works REALLY REALLY well.
    http://www.amazon.com/Permatex-84115.../dp/B000ALBZK8
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    If it's abs plastic, you can buy abs cement, or make it yourself with abs shavings + acetone. Also maybe look into jb weld? Silicone is a bit weak.
    Oct 2006
    I went with the convient way. I went to the nearest autoparts store and purchased JB-Weld Stick. Is currently working VERY well and I like it. Is also easy to applied. Think like putty/clay/play dough and you mold it into the bezel and screen.
  1. Plastic Welder - anyone used?
    By evandude in forum Fabrication
    Last Post: 11-15-2010, 11:55 AM
  2. Played with my new air-powered plastic welder
    By thebigthn in forum Fabrication
    Last Post: 05-18-2009, 08:48 PM
  3. Plastic Weld?
    By slboytoy in forum Fabrication
    Last Post: 08-31-2006, 12:51 PM
  4. what glue to use for plastic to hold screen in place
    By sr_ryan1 in forum LCD/Display
    Last Post: 09-22-2004, 07:30 PM
  5. Hot glue in PCI slots
    By ppgt94 in forum General Hardware Discussion
    Last Post: 08-16-2001, 10:59 AM
