the mp3car store itself sells ribbon cables. how many pins on it and how are they spaced apart?
I need to replace the LCD ribbon cable on a lilliput 619. While searching, most posts recommend buying the cable from http://www.digitalww.com/ . That site seems to be down for around a year now. The rests of the results are pretty much unanswered questions about where to get the ribbon cables from.
Where can I get a replacement ribbon cable for a 619?
Has anyone had any luck modding some other generic ribbon cable to make it work?
You need
.50mm FFC Low Profile Connectors 0.5mm JUMPER 40POS Type D FFC 7.00
There are two types A and D, one has pins same side, the other has the pins reveresed.
http://www.mouser.com/Search/Refine....-21020-0439%09
or
http://www.mouser.com/Search/Refine....-21020-0438%09
This is the page in their pdf, you need to look at the cabels at the bottom right.
http://www.mouser.com/catalog/633/1396.pdf
in my case is same side pins so this seems to be the closest match:
http://www.mouser.com/ProductDetail/...qT1xoAzg%3d%3d
40 pins, same side, 6 inches
