Results 1 to 10 of 19
Thread: GPS LCd > PC
    Apr 2003
    GPS LCd > PC
    Hi, Im a REAL noob at this, so ill ask my question quickly.
    What kind of plug is this, and are there adaptors I can purchase to connect it to DVI/VGA or TV-out(s-vid/composite) ?
    All I know is that it supplies power and data. I've done extensive searching and can't find anything like it....I'm assuming it's quite old..?...
    All help apreciated
    Registered User
    Oct 1999
    Model #'s or serial #'s?
    Apr 2003
    I couldn't find any information frmo the model numbers on the back of the LCD.
    But here you go.
    FA3350590
    TR-4LC2
    And the rest is in japanese
    Maybe someone here can read japanese, so here's a pic of the back.
    Sorry it's so blurry.
    Apr 2003
    Just found this; Doesn't look exactly the same, but is very similar.
    N-DV2300 Navigation System Specifications:
    _
    Power Supply - 12v DC
    Current consumption - less than 2.5A
    Dimensions - 178x50x170mm (WxDxH)
    Weight - 2.0kg
    _
    Reception frequency - 1575.42MHz
    Reception sensitivity - -130dBm
    Reception method - Parallel 8 channels
    Receiving code - C/A Code
    Channel system - Multichannel
    Channels - 8
    GPS Satellites received - 8 max.
    _
    Guide Map - DVD SDAL format
    _
    Picture Output - RGB (navigation screen) / NTSC 1.0Vp-p, 75ohms, RCA pin jack (navigation screen)
    _
    Analogue audio output - Monaural 1ch 1.5Vrms (1kHz, 0dB)
    _
    GPS Antenna
    Type - Microstrip Planer
    Dimensions - 42x14x50mm
    Weight - 120g
    _
    Remote Control
    Dimensions - 41x40x155mm
    Weight - 65g
    _
    Infrared Receiver
    Dimensions - 34x17x22mm
    Weight - 60g
    Basically that still doesn't help me much, but it could help someone help me
    Variable Bitrate mp3hombre's Avatar
    Aug 2002
    Montreal / Los Angeles
    Damn, this is the kind of gadgets I like to get my hands on!
    It is perfect for the hobbyist.
    If you are handy with a soldering iron and a multimeter, PM me and I'll give you some tips on how to figure out the inputs/outputs and power connections.
    Apr 2003
    I fonud out what kind of plug it was last night. Its an old Atari ST monitor plug.
    Heres the ST > VGA converter http://gem.win.co.nz/mb/atarihw/stvga.html
    And I'll need a DVI > VGA to go with it.
    Thank god because I couldn't be worse with a sodering iron.
    Thanks for all the help everyone. Hopefully there is a place in NZ that sells these ST>VGA adaptors.
    I'll post back soon with pics on how it runs.
    Apr 2003
    Jan 2003
    Ruston, LA
    That may be the same connector, but that adapter is not gonna do **** for you.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Apr 2003
    explain, because that doesn't exactly say alot.
    Mar 2002
    It's highly unlikely that LCD has the same pinout as the ST, even if it does use the same connector.
