it depends where you want to put the screen. and your installation requirements.
a 32" display should fit nicely after a little trimming with a sawzall![]()
So i am looking to to put a car computer in my 2005 Pathfinder anyone know the screen size ? here is a stock photo of the inside
What do you recommend for a screen as well?
Mike
32 would be sick lol I forgot to mention I want to mount mount where the radio is. I am going to pull the radio out.
HiJackZX1 w/ The Tobiathin Core PC system!
ZOTAC GF9300-G-E
INTEL E8200
4 Gigs
OCZ Vertex 2 SSD
OPUS 320
1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
Starting Raspberry Pi multizone project.
oh well, i was hoping you would like the 32" screen idea...
www.bybyte.com has a cheaper plastic double din mounting kit(compared to mp3cars expensive aluminum one) that will make a lilliput 629 bolt up.
My wife has an 05 Pathfinder. A 7" screen will fit w/ little to no modification. With a little fabrication trimming an 8" will fit as well. Depending on your fab skills you may be able to squeeze a 10" in there but that is the max I would attempt.
To measure screen size just take a tape measure and measure diagonal distance from one side corner to the other.
Mal
it's not much help, but whatever you like best-- the bybyte kit is specifically made for the 629..
the biggest difference i know of(there could be hardware/software differences also) between the 2 is that the 629 has the buttons on the bottom, and the 701 has all the buttons on the side.
She doesn't I did the measuring for a 7 or 8" and she opted for a Navigation head unit instead of a car pc.
I'm the geek, she's the beauty. Geek obeys beauty. Geek keeps beauty.
Mal
